I created an Angular 9 RC2 application and followed the instructions from your document to install a Grid. But I get the following error and can't run the angular app. How to fixt his issue?
ERROR in node_modules/igniteui-angular/lib/navigation-drawer/navigation-drawer.component.d.ts:1:84 - error TS2724: Module '"C:/LabProjects/FamilyTreePlus/FamilyTreePlusClient/node_modules/@angular/core/core"' has no exported member 'Renderer'. Did you mean 'Renderer2'? 1 import { AfterContentInit, ElementRef, EventEmitter, OnChanges, OnDestroy, OnInit, Renderer, SimpleChange } from '@angular/core'; ~~~~~~~~ node_modules/@angular/core/core.d.ts:5555:31 5555 export declare abstract class Renderer2 { ~~~~~~~~~ 'Renderer2' is declared here.
Hello Varghese,
If you are aiming to build the project with Ivy (which is now the default with Angular 9) you should update to our latest beta - 9.0.0-beta.2. In order to update to latest the beta version you should run “ng update igniteui-angular –next”.
You can refer to the following issue in our public repo regarding Angular Ivy support for more information: https://github.com/IgniteUI/igniteui-angular/issues/5849
Let me know if that resolves your issue.
Maya Kirova
