Dear support Team,
i followed your instructions for implementing filter cell templates (https://ko.infragistics.com/products/ignite-ui-angular/angular/components/grid/filtering.html)
My target ist to use an editable date picker for a date column to filter values.The click on the date input box does not switch the editor in edit mode with an input mask.
Following 2 stackblitz examples:
Wanted Behaviour in igx grid in filter cell:https://stackblitz.com/edit/angular-xml6qq
Current behaviour in igx grid in filter cell:https://stackblitz.com/edit/angular-qyivi2Is there maybe a configuration setting missing?
Thanks for your help.
Armin// Links edited
Hello Armin,
You have to use templated dropdown date picker and the igxMask directive in order to achieve your requirement.
I have created a sample in StackBlitz for your reference. Please test it on your side and let me know if that solve your issue.
