Hi Team ,
We are using Igx-grid on our application.and we do not want to show the vertical scrollbar on our grid so that we can show all rows. Can you please help on this ?
I am glad that you managed to achieve your requirement.
Hi Svetoslav,
I was giving as [height]=" 'null' ",now I corrected ,Thank you so much
Mariyam
Hello Mariyam,
Having height 100% on the parent element shouldn't affect the grid. Are you sure the scrollbar you are seeing is not coming from the parent element?
Here's an example I have made for that demonstrates the grid having height null:https://stackblitz.com/edit/angular-w7svkc
If you have any questions regarding the sample let me know.
Regards,Svetoslav
I am giving my parent height as 100%,and grid height as null , but still facing the same issue.
It will be helpful if you provide any sample codes please...
You can set the height of the grid to `null`, which will render all rows without displaying vertical scrollbar.
One thing to note though, in this case, the grid virtualization is not applied and if you have too many rows you might have performance issues.
Also we have a topic regarding the grid sizing and different scenarios, if you need more information on this: https://ko.infragistics.com/products/ignite-ui-angular/angular/components/grid/sizing.html
