I am using ignite tool for my app but at this time I realized, igx-combo component filter has not case sensitive in Turkish language.
For example :
our option is chai .. when I type 'ai' option appears ! perfect.. bu i search 'Aİ' no reaction. (you read correctly not 'AI' .. its 'Aİ' I and İ is not the same letter in turkish language)
after a couple of research I found caseSensitive input in https://www.igniteui.com/combo/filtering but when i tried to in igx-combo tagged component it doesn't work..
Also I found in here http://jsfiddle.net/umntp8dx/13/ the same situation about Turkish language (I & İ letter issue) but this is igCombo not igx-combo.
Does anyone have an opinion to way of solution here ?
Hello Ahmet,
Thank you for the cooperation and for the detailed description provided for the feature request.
Monika Kirkova,
Hello Monika,
It's my pleasure helping to improve ignite tool which I've been using for a year. I opened an issue in github repo and declared my suggestions & alternative options about it then 3 developers assigned today (good news i guess).
Thank you for caring :)
Thank you for getting back to me.
I understand your concerns. At this point Ignite UI for Angular is a relatively new product compared to the mature Ignite UI for JavaScript toolset, which has been developed for many years. Since we are trying to move forward with Ignite UI for Angular we consider our customer’s feedback crucial for steering improvements and we highly appreciate that you took time to convey your opinion. This kind of feedback helps us shape the future of our components so that it meets all kind of needs that our customer might have.
That upset me Ignite tool has this feature in jQuery but Angular.. However I am going to create feature request soon as you said. Hope the developers contact me quickly :)
Thank you.
After investigating this further, I determined that currently case sensitive filter is not supported by the igxCombo. What I can suggest is creating a feature request in our GitHub repository here if you want to see it implemented in any of our future releases. This will give you the opportunity to communicate directly with our developers and get notifications when new information regarding your query is available.
When creating the request please be sure to be specific and provide as much details as possible. Attaching a working sample, screenshots and any information that consider relevant are going to be very helpful.
Please let me know if you need more information.
Regards, Monika Kirkova, Infragistics
