75
Ignite UI for Angular edits that affect multiple cells
I have a grid that has multiple cols, one col is amount - in this case I have an unchangable total amount say 200, my first row is the parent that will hold the 'unallocated' amt. so starting off it has 200, a row is added, put in 10 and the first row needs to change to 190.  I have this working using (onCellEdit)
I have next to it a col of the %'s related to these dollar amounts.  So when I enter the 10 its % needs to change to 5% and the top row when its value changes to 190 it also needs to change the % to 95.  I have this mostly working in (onCellEdit)
The problem is both cols are editable, and if I directly change a $ and click directly into its % the old percentage is showing in the edit.  I need to have it updated prior to going into edit - but how?
Pictures are worth 1000 words.
This is my grid with amounts and %s correct - before a change:
change one amount:
tab directly into the % - the value of 77 should change, but this is what i see when i directly click into it. you can see that my top row dollar amount has been changed, and the % of the first row also is updated.
If I move off this it then gets updated:
I don't know if there is a way to get it to do the calculations AS the user types instead of (onCellEdit) which seems to get hit after you leave the cell?  Or is there a way to get this to complete prior to getting the 'enter edit mode'?
