Hello everyone,
I have cards with ngFor loop and i re-organize them with igxDrag & igxDrop but anytime I click button or routerLink a element inside of drag div ... (dragClick) event triggers in igxDrag and I can not handle click event any element in drag div..
does anyone have solution or suggest for this ?
thank you all.
Hello Ahmet,
I am glad that you find my suggestion helpful.
Hopefully you subscribed to the GitHub issue to be up to date with its status.
Thank you for using Infragistics componnets.
Best Regards,Martin EvtimovEntry Level Software DeveloperInfragistics, Inc.
Hello Martin,
Thanks for answer and suggest. Your feature is really good i looked it up and watch github issue :)
Your stopEventPropagation method suggestion is cool I will use it thanks.
My other solution is igxDragHandle directive. (but just for now ignite have to create new feature just like angular material drag-drop component)
I divided div with top & bottom and actions buttons inside of bottom div so I added igxDragHandle directive to top div.
Anyway your igxDragIgnore directive suggestion has to come quickly :)
Thank you & stay safe.
Thank you for contacting Infragistics Community!
I have investigated the described behavior and it seems to be an issue with the igxDragIgnore Directive which I have logged in our GitHub Repository. My suggestion would be to subscribe to this issue in order to get notifications whenever a new information is available. Feel free to add any additional information, or questions that you might have.
In the meantime I suggest the following workaround:
I have prepared the following sample for you where I have implemented the suggested workaround.
Please let me know if you need any further assistance with this matter.
Thank you for choosing Infragistics components!
Best Regards, Martin Evtimov Entry Level Software Developer Infragistics, Inc.
