1415
Igx grid Sum of columns of two different grids should not be more than 100
I am using two Igx data grid.
Scenario: I have 2 grids, sum of particular columns of two grid should be not greater than 100. In grid1 (grid) and grid2 (grid1), there is a column in each grid with datatype number and that sum should be = 100. How can i achieve the same? If the sum is greater than 100 than toast error should display.
Have attached the sample Stackbliz: https://stackblitz.com/edit/angular-grid-decimal-places?file=src%2Fapp%2Fgrid%2Fgrid-allData-summary%2Fgrid-allData-summary.component.html
Kindly help for the same.
