hello, i am using this element https://ko.infragistics.com/products/ignite-ui-angular/angular/components/switch.html, Could someone help me with an example of how to execute a method in the change event.
Hello Erick,
I am glad that you find my suggestion helpful and were able to solve your issue.
Monika Kirkova,
Thank you very much, this solves it.
After investigating this further, I determined that your requirement could be achieved by binding a method to the change event the following way:
<igx-switch checked="true" (change)="stateChanged($event)">
The method stateChanged is defined in the ts file:
public stateChanged(evt){
if(evt.checked)
console.log("Switch is now checked!");
else {
console.log("Switch is now unchecked!");
I have prepared a sample, demonstrating the described behavior. Please test it on your side and let me know if you need additional information regarding this matter.
