215
Column formatter with excel filters not working properly
Hi
I am using the formatter for several grid columns to apply formatting on numbers to required decimal places. The problem I am seeing is that if you have multiple values which format to same value they still show independently in the list. So for example if I format 0.0001 and 0.0002 to 2dp then they both become 0.00 but I would see 0.00 appear twice in the list. Each item then only selects it's underlying item
Is there a way to ensure that the excel style filter takes into account the formatter? In it's current state I can't see how using formatters is possible with filtering since the duplicate options referring to different entries make it impossible to use.
Is there any way to get it working so that if things format to same value that they appear once and select all related values?
