30
IgxTimePicker initial value
I am wondering how can i set the initial time for the TimePicker when there is no value, currently it is always 4 AM.
I don't want to limit user with a min and max range but for example start at 8 AM instead of 4 AM when it drops down
  • 60
    Hello Frank,
    Thank you for contacting Infragistics Support.
    I have been looking into your question and prepared a small sample that you might consider useful. It could be found here. As you can observe, I am using the [(ngModel)] and I defined a global variable where is stored the default value in order to achieve your requirement.
    Please have a look at the provided sample and if it is not an accurate demonstration of what you are trying to achieve please feel free to modify it and send it back to me for further investigation.
    Malin Hadzhiev
