485
Message trial version!
HI:
I am trying to start a new application in ignite
Due to an error, I installed version 11 but I don't have a license to use it
Then install the version with 10.2.0 that I have licensed.
But even so, the grid, shows the test version message
Also when I try to install it from private feed tells me that the version is not there
what should I do?
Pablo
  • 740
    Hello Pablo,
    Thank you for contacting Infragistics Support!
    Please note that as soon as your license expires and you do not renew you will be still able to use the last version that you have installed (and is currently downloaded in your node_modules folder) before the license expiration. However you will be no longer eligible for downloading any of the IgniteUI for Angular licensed packages due to the subscription based licensing of the IgniteUI for Angular library. Having this in mind once you have removed the licensed IgniteUI for Angular packages after your license has expired you won’t be able to download them back upon license renew.
    Please let me know if you need any further information.
    Best Regards,
    Martin Evtimov
    Associate Software Developer
    Infragistics, Inc.
