I'm trying to use the action strip component, with the igx-grid-editing-actions, which provides the user with three in-built actions: add(if user sets [addRow]="true"), edit, delete.
For the Delete action, I'm trying to find out which event gets fired so that I can dynamically write code according to requirement.
Attached is the code snippet, and the image of the action strip with the igx-grid-editing-actions.
Anvitha.
<igx-action-strip #actionstrip> <igx-grid-editing-actions [addRow]="true" [asMenuItems]="true"></igx-grid-editing-actions> </igx-action-strip>
Hello Anvitha,
Thank you for reaching out.
The igx-action-button emits the actionClick event, when choosing any option from the <igx-grid-editing_actions> menu. However, the igx-grid-editing-actions consumes the event and does not re-emit it further. Currently the <igx-editing-actions>could be replaced with the button itself, and the event handler could be attached to the actionClick through the button. For example:
<igx-action-strip #actionstrip> <igx-grid-action-button iconName="delete" [labelText]="delete" (actionClick)="clickHandler($event)"></igx-grid-action-button> </igx-action-strip>
Since there might be a better approach for achieving your requirement, please elaborate on what is the behavior that you are looking for when the button is clicked, so that I can investigate it further.
Viktor Kombov
Infragistics, Inc.
