935
Latest demo package isn't working
The demo package is not working. Most of the issue is with gyp. I had to install python 2 to get that far. Here is the remaining log of errors:
5797 verbose stack Error: command failed
5797 verbose stack     at ChildProcess.<anonymous> (C:\Users\CSWOREN\AppData\Roaming\npm\node_modules\npm\node_modules\@npmcli\promise-spawn\index.js:64:27)
5797 verbose stack     at ChildProcess.emit (node:events:365:28)
5797 verbose stack     at maybeClose (node:internal/child_process:1067:16)
5797 verbose stack     at Process.ChildProcess._handle.onexit (node:internal/child_process:301:5)
5798 verbose pkgid node-sass@4.14.1
5799 verbose cwd C:\Users\CSWOREN\Downloads\Infragistics_Angular_v20-2\igniteui-angular-samples-11.0.0
5800 verbose Windows_NT 10.0.18363
5801 verbose argv "C:\\Program Files\\nodejs\\node.exe" "C:\\Users\\CSWOREN\\AppData\\Roaming\\npm\\node_modules\\npm\\bin\\npm-cli.js" "i" "--legacy-peer-deps"
5802 verbose node v16.1.0
5803 verbose npm  v7.8.0
5804 error code 1
5805 error path C:\Users\CSWOREN\Downloads\Infragistics_Angular_v20-2\igniteui-angular-samples-11.0.0\node_modules\node-sass
5806 error command failed
5807 error command C:\WINDOWS\system32\cmd.exe /d /s /c node scripts/build.js
5808 error Building: C:\Program Files\nodejs\node.exe C:\Users\CSWOREN\Downloads\Infragistics_Angular_v20-2\igniteui-angular-samples-11.0.0\node_modules\node-gyp\bin\node-gyp.js rebuild --verbose --libsass_ext= --libsass_cflags= --libsass_ldflags= --libsass_library=
5809 error gyp info it worked if it ends with ok
5809 error gyp verb cli [
5809 error gyp verb cli   'C:\\Program Files\\nodejs\\node.exe',
5809 error gyp verb cli   'C:\\Users\\CSWOREN\\Downloads\\Infragistics_Angular_v20-2\\igniteui-angular-samples-11.0.0\\node_modules\\node-gyp\\bin\\node-gyp.js',
5809 error gyp verb cli   'rebuild',
5809 error gyp verb cli   '--verbose',
5809 error gyp verb cli   '--libsass_ext=',
5809 error gyp verb cli   '--libsass_cflags=',
5809 error gyp verb cli   '--libsass_ldflags=',
5809 error gyp verb cli   '--libsass_library='
5809 error gyp verb cli ]
5809 error gyp info using node-gyp@3.8.0
5809 error gyp info using node@16.1.0 | win32 | x64
5809 error gyp verb command rebuild []
5809 error gyp verb command clean []
5809 error gyp verb clean removing "build" directory
5809 error gyp verb command configure []
5809 error gyp verb check python checking for Python executable "python2" in the PATH
5809 error gyp verb `which` failed Error: not found: python2
5809 error gyp verb `which` failed     at getNotFoundError (C:\Users\CSWOREN\Downloads\Infragistics_Angular_v20-2\igniteui-angular-samples-11.0.0\node_modules\which\which.js:13:12)
5809 error gyp verb `which` failed     at F (C:\Users\CSWOREN\Downloads\Infragistics_Angular_v20-2\igniteui-angular-samples-11.0.0\node_modules\which\which.js:68:19)
5809 error gyp verb `which` failed     at E (C:\Users\CSWOREN\Downloads\Infragistics_Angular_v20-2\igniteui-angular-samples-11.0.0\node_modules\which\which.js:80:29)
5809 error gyp verb `which` failed     at C:\Users\CSWOREN\Downloads\Infragistics_Angular_v20-2\igniteui-angular-samples-11.0.0\node_modules\which\which.js:89:16
5809 error gyp verb `which` failed     at C:\Users\CSWOREN\Downloads\Infragistics_Angular_v20-2\igniteui-angular-samples-11.0.0\node_modules\isexe\index.js:42:5
5809 error gyp verb `which` failed     at C:\Users\CSWOREN\Downloads\Infragistics_Angular_v20-2\igniteui-angular-samples-11.0.0\node_modules\isexe\windows.js:36:5
5809 error gyp verb `which` failed     at FSReqCallback.oncomplete (node:fs:194:21)
5809 error gyp verb `which` failed  python2 Error: not found: python2
5809 error gyp verb `which` failed     at FSReqCallback.oncomplete (node:fs:194:21) {
5809 error gyp verb `which` failed   code: 'ENOENT'
5809 error gyp verb `which` failed }
5809 error gyp verb check python checking for Python executable "python" in the PATH
5809 error gyp verb `which` succeeded python C:\Python39\python.EXE
5809 error gyp ERR! configure error
5809 error gyp ERR! stack Error: Command failed: C:\Python39\python.EXE -c import sys; print "%s.%s.%s" % sys.version_info[:3];
5809 error gyp ERR! stack   File "<string>", line 1
5809 error gyp ERR! stack     import sys; print "%s.%s.%s" % sys.version_info[:3];
5809 error gyp ERR! stack                       ^
5809 error gyp ERR! stack SyntaxError: invalid syntax
5809 error gyp ERR! stack     at ChildProcess.exithandler (node:child_process:326:12)
5809 error gyp ERR! stack     at ChildProcess.emit (node:events:365:28)
5809 error gyp ERR! stack     at maybeClose (node:internal/child_process:1067:16)
5809 error gyp ERR! stack     at Process.ChildProcess._handle.onexit (node:internal/child_process:301:5)
5809 error gyp ERR! System Windows_NT 10.0.18363
5809 error gyp ERR! command "C:\\Program Files\\nodejs\\node.exe" "C:\\Users\\CSWOREN\\Downloads\\Infragistics_Angular_v20-2\\igniteui-angular-samples-11.0.0\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild" "--verbose" "--libsass_ext=" "--libsass_cflags=" "--libsass_ldflags=" "--libsass_library="
5809 error gyp ERR! cwd C:\Users\CSWOREN\Downloads\Infragistics_Angular_v20-2\igniteui-angular-samples-11.0.0\node_modules\node-sass
5809 error gyp ERR! node -v v16.1.0
5809 error gyp ERR! node-gyp -v v3.8.0
5809 error gyp ERR! not ok
5809 error Build failed with error code: 1
5810 verbose exit 1
