I am attempting to deploy my working version to an Azure DevOps hosting site and I am getting the following error:
14292 error code E404 14293 error 404 Not Found - GET https://registry.npmjs.org/@infragistics%2figniteui-angular - Not found 14294 error 404 14295 error 404 '@infragistics/igniteui-angular@12.0.3' is not in the npm registry. 14296 error 404 You should bug the author to publish it (or use the name yourself!) 14297 error 404 It was specified as a dependency of 'UI' 14298 error 404 Note that you can also install from a 14299 error 404 tarball, folder, http url, or git url. 14300 verbose exit [ 1, true ] ##[error]Error: Npm failed with return code: 1
Is there something I need to add to the YML/TF scripts for the build pipeline in order to access the paid subscription so my build goes through properly? I remember having to set a build variable in NPM for my local but I can't find the page and I don't remember it saying anything about applying the same changes to an automated build location.
I'm glad that you were able to configure your Azure pipeline to install our @infragistics/igniteui-angular package.
The error indicates that the npm is still not configured and when installing our package, npm still searches it under the npmjs.org repo(GET https://registry.npmjs.org/@infragistics....). You can check the .npmrc file after the configuration steps by outputting it with npm list command. You can try to update the .npmrc file by redirecting the output with "TEXT" >> ~/.npmrc.Another thing is to check whether you have a local .npmrc file per your project, which "shadows" the global one which has been updated with above steps.
I have integrated the steps and variables as specified and am still getting errors:
14884 verbose stack Error: 404 Not Found - GET https://registry.npmjs.org/@infragistics%2figniteui-angular - Not found 14884 verbose stack at /opt/hostedtoolcache/node/12.22.1/x64/lib/node_modules/npm/node_modules/npm-registry-fetch/check-response.js:117:15 14884 verbose stack at runMicrotasks (<anonymous>) 14884 verbose stack at processTicksAndRejections (internal/process/task_queues.js:97:5) 14885 verbose statusCode 404 14886 verbose pkgid @infragistics/igniteui-angular@12.0.3 14887 verbose cwd /home/vsts/work/1/s/UI 14888 verbose Linux 5.8.0-1033-azure 14889 verbose argv "/opt/hostedtoolcache/node/12.22.1/x64/bin/node" "/opt/hostedtoolcache/node/12.22.1/x64/bin/npm" "install" 14890 verbose node v12.22.1 14891 verbose npm v6.14.12 14892 error code E404 14893 error 404 Not Found - GET https://registry.npmjs.org/@infragistics%2figniteui-angular - Not found 14894 error 404 14895 error 404 '@infragistics/igniteui-angular@12.0.3' is not in the npm registry. 14896 error 404 You should bug the author to publish it (or use the name yourself!) 14897 error 404 It was specified as a dependency of 'UI' 14898 error 404 Note that you can also install from a 14899 error 404 tarball, folder, http url, or git url. 14900 verbose exit [ 1, true ] ##[error]Error: Npm failed with return code: 1 Finishing: npm install
I am directly injecting the variables (blocking IG token below) in my ui-pipelines.yml:
# Starter pipeline # Start with a minimal pipeline that you can customize to build and deploy your code. # Add steps that build, run tests, deploy, and more: # https://aka.ms/yaml trigger: branches: include: - master paths: include: - UI/* pool: vmImage: 'ubuntu-latest' steps: - script: npm config set @infragistics:registry https://packages.infragistics.com/npm/js-licensed/ displayName: 'Npm add registry' - script: npm config set //packages.infragistics.com/npm/js-licensed/:always-auth=true displayName: 'Npm config' - script: npm config set //packages.infragistics.com/npm/js-licensed/:_auth=*************************************** displayName: 'Npm config auth' - task: NodeTool@0 displayName: 'Use Node 12.x' inputs: versionSpec: '12.x' - task: Npm@1 displayName: 'Angular CLI' inputs: command: custom workingDir: UI verbose: false customCommand: 'install -g @angular/cli@latest' - task: Npm@1 displayName: 'npm install' inputs: command: install workingDir: UI - task: Npm@1 displayName: 'Build' inputs: command: custom workingDir: UI verbose: false customCommand: 'run build' - task: ArchiveFiles@2 inputs: rootFolderOrFile: '$(Build.SourcesDirectory)/UI/dist/commits' includeRootFolder: false archiveType: 'zip' archiveFile: '$(Build.ArtifactStagingDirectory)/$(Build.BuildId).zip' replaceExistingArchive: true - task: PublishBuildArtifacts@1 inputs: PathtoPublish: '$(Build.ArtifactStagingDirectory)' ArtifactName: 'drop' publishLocation: 'Container'
Can you please tell me why it's still failing?
Looking at the error that you are getting, it seems that you are missing the configuration for our private repository. We have an article which you can refer to for more details how to setup your Azure DevOps build - https://ko.infragistics.com/products/ignite-ui-angular/angular/components/general/ignite-ui-licensing#azure-pipelines-configuration.
Please let me know whether I can assists you with anything else on the matter.
