175
Angular Chart Overlays over Time range?
A bit of background on what I am trying to do.  I have a Line Chart that is going to be plotting power consumption on the Y-Axis over time on the X-Axis.  One of the requirements for this chart is when power goes above or below a certain threshold, I need to be able to color code that time range accordingly (for example if power exceeds 1000 Watts from July 1st - July 3rd, I need to be able to indicate that time range as red on the graph background).
I was looking at the Angular chart overlays, and thought this might work, however, it looks like this particular feature as far as I can tell, does not support a time range, and only supports a single value, would that be correct?  Is there another possible way to meet this requirement?
Any help or insight would be appreciated.
-Randall Blevins
  • 34810
    Hello Randall,
    I have been investigating into the behavior you are looking to achieve, and I am under the impression that you are looking for a Line Chart where the line may be a different color when placed above a certain threshold. If this is not the case, please let me know as the following is based on that impression.
    In order to have this functionality in the IgxDataChartComponent, I would recommend using multiple IgxLineSeries instances where you can define a value path in your data source for each part of the threshold, as a “threshold line” chart would not be possible with a single IgxLineSeries.
    Regarding the overlays, I am assuming you are referring to the IgxValueOverlay, in which case, you are correct that there can only be a single value that that particular overlay takes, although you can have more than one overlay if you would like.
    If you would like to see a “threshold line series” potentially implemented in a future version of the Ignite UI for Angular toolset, I would recommend suggesting a new product idea for this at our Angular Ideas Site, here: https://ko.infragistics.com/community/ideas/i/ignite-ui-for-angular. This will place you in direct communication with our product management teams who plan and prioritize upcoming features and development based on community and user feedback.
