15
Issue when trying to add a new Row to the data grid, and edit that particular newly added row
I have an issue with igniteui data grid when add a new editable row. So for demoing that I have attached the stackblitz link, a screen to gif capture, and the typescript and html code.
The issue here being on the row edit done click we need to be able to add a new blank empty row and that seems to work fine and when the newly added first row is being edited its seems to be fine then too. And when we click on the done of the newly added row after the edit, another new empty row will be created. So, in this scenario, when I try the double click to go into the edit mode of the second newly added row, the cancel and done banner will overlap on the row. Not sure why this behavior is seen. Could you please help me solve this and find me away. I would appreciate that.
To demo this I have attached all the required code, and links.
Anvitha.
https://github-bsgwpw.stackblitz.io/
<div class="sample-wrapper">
    <igx-grid #grid [data]="data" width="100%" height="500px" [primaryKey]="'ProductID'" [rowEditable]="true"
        (rowEditExit)="rowEditExit($event)">
        <igx-column field="ProductID" header="Product ID" [editable]="true"></igx-column>
        <igx-column field="ReorderLevel" header="ReorderLever" dataType="number" [editable]="true"></igx-column>
        <igx-column field="ProductName" header="ProductName" [dataType]="'string'" [editable]="true"></igx-column>
        <igx-column field="OrderDate" [dataType]="'date'" [editable]="true"></igx-column>
        <igx-column class="actionstripheader1" width="67.5px">
            <igx-action-strip class="actionstrip" #actionstrip>
                <button title="Delete" igxButton="icon" igxRipple (click)="deleteRow(actionstrip.context)">
            <igx-icon>delete</igx-icon>
        </button>
            </igx-action-strip>
        </igx-column>
    </igx-grid>
</div>
        </button>
            </igx-action-strip>
        </igx-column>
    </igx-grid>
</div>
.sample-wrapper {
    margin: 0 auto;
    padding: 10px;
/* eslint-disable */
export const DATA: any[] = [
    ProductID: 1,
    ProductName: 'Chai',
    SupplierID: 1,
    CategoryID: 1,
    QuantityPerUnit: '10 boxes x 20 bags',
    UnitPrice: 18.0,
    UnitsInStock: 39,
    UnitsOnOrder: 30,
    ReorderLevel: 10,
    Discontinued: false,
    OrderDate: new Date('2012-02-12')
    ProductID: 2,
    ProductName: 'Chang',
    SupplierID: 1,
    CategoryID: 1,
    QuantityPerUnit: '24 - 12 oz bottles',
    UnitPrice: 19.0,
    UnitsInStock: 17,
    UnitsOnOrder: 40,
    ReorderLevel: 25,
    Discontinued: true,
    OrderDate: new Date('2003-03-17')
    ProductID: 3,
    ProductName: 'Aniseed Syrup',
    SupplierID: 1,
    CategoryID: 2,
    QuantityPerUnit: '12 - 550 ml bottles',
    UnitPrice: 10.0,
    UnitsInStock: 13,
    UnitsOnOrder: 70,
    ReorderLevel: 25,
    OrderDate: new Date('2006-03-17')
    ProductID: 4,
    ProductName: 'Chef Antons Cajun Seasoning',
    SupplierID: 2,
    CategoryID: 2,
    QuantityPerUnit: '48 - 6 oz jars',
    UnitPrice: 22.0,
    UnitsInStock: 53,
    UnitsOnOrder: 30,
    ReorderLevel: 0,
    OrderDate: new Date('2016-03-17')
    ProductID: 5,
    ProductName: 'Chef Antons Gumbo Mix',
    SupplierID: 2,
    CategoryID: 2,
    QuantityPerUnit: '36 boxes',
    UnitPrice: 21.35,
    UnitsInStock: 0,
    UnitsOnOrder: 30,
    ReorderLevel: 0,
    Discontinued: true,
    OrderDate: new Date('2011-11-11')
    ProductID: 6,
    ProductName: 'Grandmas Boysenberry Spread',
    SupplierID: 3,
    CategoryID: 2,
    QuantityPerUnit: '12 - 8 oz jars',
    UnitPrice: 25.0,
    UnitsInStock: 0,
    UnitsOnOrder: 30,
    ReorderLevel: 25,
    OrderDate: new Date('2017-12-17')
/* tslint:enable */
  • 1560
    Thank you for the provided details.
    I was not able to open the attached demo and also I cannot see any typescript code, however, based on the provided markup file and gif,  my assumption is that a new row is added via the rowEditExit event handler i.e. after some row is edited. Since the grid's primaryKey is set to the ProductID field and after a new row is added I'm not seeing a value in this field I'm assuming that you are adding an empty object without a primary key value. However, the second time you add a new empty row, there would be two rows with equal primary keys (i.e. undefined) which should be unique.
    The primary key is mandatory for row editing operations and in case it is not unique it is expected to have some side effects on the grid's behavior.
    What I could suggest in order to prevent such issues is to set the primary key using some logic depending on your scenario and make sure it is unique.
    I have prepared a small sample that demonstrates a possible approach and it could be found here.
    Please test it on your side and let me know if I may be of any further assistance.
    Sincerely,
    Teodosia Hristodorova
    Associate Software Developer
