15
Can I bind columns for tree grid to json data instead of fixed in the template
Hi, I have just started a trial and looking at the Tree grid. Starting with the `tree-grid-virtualization-sample` example.
I wanted to be able support the case where I do not know what columns I have until runtime, so rather than hard coding them into the template, wante dto be able to format them in data, and do something like...
And then in code behind have something like...
this.columns  = [
      { dataField: "location", caption: "Location", allowResizing: true },
        dataField: "room", caption: "Room", alignment: 'right', allowEditing: true, allowResizing: true,
        cellTemplate: 'cellTemplate', headerCellTemplate: 'headerTemplate'
      { dataField: "cleanertype", caption: "cleaner type" },
      { dataField: "cleanerweight", caption: "cleaner weight" },
      { dataField: "totalweight", caption: "total weight" },
Ie defined the fieldnames, caption, and either cell templates or some sort of custom rendering.
Is this possible with these components?
Thanks i advance
  • 20
    I am currently working on this and will update once I have more information.
    Best regards,
    Developer support
  • 15
    Actually I think I found the answer in hidden in sample tree-grid-conditional-cell-style-
    ie we use a *ngFor
    igx-column *ngFor="let c of columns"
                [field]="c.field"
                [header]="c.headerc.header : c.field"
                [cellStyles]="c.cellStyles">
    </igx-column>
