Hi Team,
I am using Financial/Stock charts and binding the time series data to the chart. The chart is rendered fine but the tooltip shows the date in the format of date and time where time is not required in our case. So even if it is only the date it is adding "00:00:00" after the date.
Even the samples provided in www.infragistics.com/.../stock-chart has the same behaviour. Can you please provide inputs or an example on how to remove time part in date.
Please note that I have already tried to format the date field to only date string but the x axis is showing incorrect date values after the change.
Looking forward to the inputs.
Hi Noriko, Thanks for responding.
I have got the solution from this post. https://ko.infragistics.com/community/forums/f/ignite-ui-for-angular/123477/remove-time-part-from-the-data-in-financial-stock-chart
Thank you for posting the inquiry to our forum.
We are now looking into it. As it is likely it will take some more time to give you a reply, could you wait for a while?
Thank you in advance for your patience.
