He team,We are moving from trail to licensed version. We followed the given instruction from Ignite UI Licensing (infragistics.com) . And we added below lines in file .npmrc
@infragistics:registry=packages.infragistics.com/.../ //packages.infragistics.com/npm/js-licensed/:_auth=my_token //packages.infragistics.com/npm/js-licensed/:_password=pass //packages.infragistics.com/npm/js-licensed/:username=username!!infragistics.com //packages.infragistics.com/npm/js-licensed/:email=username@infragistics.com //packages.infragistics.com/npm/js-licensed/:always-auth=true
After run ig upgrade-packages command we got the following error
Logged in as username to scope @infragistics on packages.infragistics.com/.../.Installing npm packages.npm WARN deprecated chokidar@2.1.8: Chokidar 2 will break on node v14+. Upgrade to chokidar 3 with 15x less dependencies.npm WARN deprecated fsevents@1.2.13: fsevents 1 will break on node v14+ and could be using insecure binaries. Upgrade to fsevents 2.npm WARN deprecated flatten@1.0.3: flatten is deprecated in favor of utility frameworks such as lodash.npm ERR! code E401npm ERR! 401 Unauthorized - GET packages.infragistics.com/.../@infragistics/igniteui-angular - Unauthorized.
Version - angular - 10.0.0
ignite ui angular (trail) - 10.0.0
Hi I have logged in ProGet site. and under js-licensed I can see iginteui-angular package (version- 0.0.1) and there are few other packages too.
Hi,I have logged in ProGet site and under js-licensed I can see iginteui-angular package.
Could you please try to login to our ProGet site, and check whether do you see iginteui-angular package under the js-licensed feed here?
Sincerely,
Teodosia Hristodorova
Associate Software Developer
I have tried again, still got the same error.
Hello, I noticed that there is an additional forum thread regarding the same query. Please, keep in mind that according to our support policy we handle a single thread per issue. This helps us ensure that all issues are addressed and handled correctly.Please take a look at this forum thread where I have already provided an answer and let me know if you have any additional questions. Thank you for using Infragistics components.Sincerely,Teodosia HristodorovaAssociate Software Developer
