30
Igx-switch width
Hi, does anyone know the best way to change the width of the igx-switch component? And is there a way to make the length of the switch longer and the circular switch button smaller?
  • 1500
    Suggested Answer
    After investigating this matter further and doing some research, changing the width of the switch checkbox has been determined to be a feature request. You can submit feature request in our GitHub repository here.
    Remember when submitting your idea to explain the context in which a feature would be used and why it is needed as well as anything that would prevent you from accomplishing this today. You can even add screenshots to build a stronger case.
    This will give you the opportunity do directly communicate with our development team regarding the issue and get notifications whenever a new information is available.
    Alternatively, you can play a bit with the css classes, however here you will have to adjust values yourself. Here is a sample of the classes that need to be overwritten to achieve wider slide on the icon with smaller dot inside:
    :host {
        ::ng-deep {
            // this is for the dimensions of the background slider
           .igx-switch__composite{
            width3.25rem;
            height0.875rem;
           // here you can adjust the circular switch and make it smaller if needed
           .igx-switch__composite-thumb {
            width15px;
            height15px;
            min-width10px;
            border-radius50%;
            displayinline-block;
            border-colorgray;
           // this will control the lenght of the animation between states
           .igx-switch--checked .igx-switch__composite-thumb {
            transformtranslateX(2.2rem);
    Please let me know if you need any further assistance.
    Tihomir Tonev
    Associate Software Developer
