30
switching between tabs and update the WindowTab Object
By default , I can switch between tab also. but I am unable to update the order of tabs in the object (WindowTab). Once i change the order , it will reflect in screen but the object is not updated .
How can i update the object? In what basis?
  • 640
    Hello Nikolay,
    Thank you for reaching out.
    In order to ensure that your issue is addressed correctly, I will need some additional information regarding your scenario. Can you please confirm that you are using the IgxTabs component and clarify what do you mean by "WindowTab"? Is it possible to provide me with a sample that reproduces the described behavior?
    Having a working sample on my side, which I can debug, is going to be very helpful in finding the root cause of this behavior.
    Viktor Kombov
    Infragistics, Inc.
