I am using AG/IG ~12.3,
I get the following build errors in Azure (but not in local):
Error: node_modules/igniteui-angular-spreadsheet/lib/CustomDOMEventProxy.d.ts:11:15 - error TS2416: Property 'cp' in type 'CustomDOMEventProxy' is not assignable to the same property in base type 'CanvasGestureDOMEventProxy'. Type '(a: NormalizedEvent) => void' is not assignable to type '() => void'. 11 protected cp(a: NormalizedEvent): void; ~~ Error: node_modules/igniteui-angular-spreadsheet/lib/CustomDOMEventProxy.d.ts:12:15 - error TS2416: Property 'cq' in type 'CustomDOMEventProxy' is not assignable to the same property in base type 'CanvasGestureDOMEventProxy'. Type '(a: NormalizedEvent) => void' is not assignable to type '() => void'. 12 protected cq(a: NormalizedEvent): void; ~~ Error: node_modules/igniteui-angular-spreadsheet/lib/SpreadsheetChartAdapterBase_combined.d.ts:3388:22 - error TS2415: Class 'SpreadsheetDOMEventProxy' incorrectly extends base class 'CustomDOMEventProxy'. Property 'dq' is private in type 'CustomDOMEventProxy' but not in type 'SpreadsheetDOMEventProxy'. 3388 export declare class SpreadsheetDOMEventProxy extends CustomDOMEventProxy {
It seems to be related to Ignite UI Spreadsheet, but we haven't updated it or changed its functionality at all since the last build which had no issues.
Alternatively, since we assume that this is related to an unpublished change (it's been working fine until now), I am attempting to upgrade to 13.3 with no luck. I am completely unable to run my app in local because no amount of memory allocated seems to sufficient. There's always a form of the message "JavaScript heap out of memory" with a list of GCs requesting an extra 1-1.5GB. I have 48GB on my system and have allocated from 4GB up to 40GB without successfully starting the app.
The worst is in cases like when I assign 8GB and it immediately spits out this failure message without any useful description at all:
> start > node --max_old_space_size=8192 node_modules/@angular/cli/bin/ng s -o <--- Last few GCs ---> <--- JS stacktrace ---> # # Fatal javascript OOM in GC during deserialization #
Everything I read just says give it more memory, but the app ran with 10GB before this attempt to deploy. The error log shows its' only allocating 1.7GB and only using 1.44GB even though I'm attempting to allocate more:
{ "header": { "reportVersion": 2, "event": "Allocation failed - JavaScript heap out of memory", "trigger": "FatalError", "filename": "report.20220411.154217.23116.0.001.json", "dumpEventTime": "2022-04-11T15:42:17Z", "dumpEventTimeStamp": "1649716937092", "processId": 23116, "threadId": 0, "cwd": "C:\\Users\\csworen\\source\\repos\\Commits\\UI", "commandLine": [ "node", "--max_old_space_size=16000", "--report-on-fatalerror", "node_modules/@angular/cli/bin/ng", "s" ], "nodejsVersion": "v16.13.0", "wordSize": 32, "arch": "ia32", "platform": "win32", "componentVersions": { "node": "16.13.0", "v8": "9.4.146.19-node.13", "uv": "1.42.0", "zlib": "1.2.11", "brotli": "1.0.9", "ares": "1.17.2", "modules": "93", "nghttp2": "1.45.1", "napi": "8", "llhttp": "6.0.4", "openssl": "1.1.1l+quic", "cldr": "39.0", "icu": "69.1", "tz": "2021a", "unicode": "13.0", "ngtcp2": "0.1.0-DEV", "nghttp3": "0.1.0-DEV" }, "release": { "name": "node", "lts": "Gallium", "headersUrl": "https://nodejs.org/download/release/v16.13.0/node-v16.13.0-headers.tar.gz", "sourceUrl": "https://nodejs.org/download/release/v16.13.0/node-v16.13.0.tar.gz", "libUrl": "https://nodejs.org/download/release/v16.13.0/win-x86/node.lib" }, "osName": "Windows_NT", "osRelease": "10.0.19044", "osVersion": "Windows 10 Enterprise", "osMachine": "i686", "cpus": [ { "model": "11th Gen Intel(R) Core(TM) i7-1185G7 @ 3.00GHz", "speed": 2995, "user": 1038484, "nice": 0, "sys": 1540937, "idle": 13208453, "irq": 160406 }, { "model": "11th Gen Intel(R) Core(TM) i7-1185G7 @ 3.00GHz", "speed": 2995, "user": 839921, "nice": 0, "sys": 964437, "idle": 13983328, "irq": 16453 }, { "model": "11th Gen Intel(R) Core(TM) i7-1185G7 @ 3.00GHz", "speed": 2995, "user": 1545906, "nice": 0, "sys": 1332734, "idle": 12909046, "irq": 14062 }, { "model": "11th Gen Intel(R) Core(TM) i7-1185G7 @ 3.00GHz", "speed": 2995, "user": 1137937, "nice": 0, "sys": 1257250, "idle": 13392500, "irq": 10593 }, { "model": "11th Gen Intel(R) Core(TM) i7-1185G7 @ 3.00GHz", "speed": 2995, "user": 1247468, "nice": 0, "sys": 1341546, "idle": 13198656, "irq": 16031 }, { "model": "11th Gen Intel(R) Core(TM) i7-1185G7 @ 3.00GHz", "speed": 2995, "user": 1041234, "nice": 0, "sys": 1081984, "idle": 13664453, "irq": 12171 }, { "model": "11th Gen Intel(R) Core(TM) i7-1185G7 @ 3.00GHz", "speed": 2995, "user": 1252171, "nice": 0, "sys": 1345484, "idle": 13190015, "irq": 11953 }, { "model": "11th Gen Intel(R) Core(TM) i7-1185G7 @ 3.00GHz", "speed": 2995, "user": 1304843, "nice": 0, "sys": 1126812, "idle": 13356015, "irq": 9218 } ], "networkInterfaces": [ { "name": "Ethernet", "internal": false, "mac": "00:05:9a:3c:7a:00", "address": "10.212.177.158", "netmask": "255.255.240.0", "family": "IPv4" }, { "name": "Wi-Fi", "internal": false, "mac": "84:14:4d:13:86:0c", "address": "192.168.1.196", "netmask": "255.255.255.0", "family": "IPv4" }, { "name": "Loopback Pseudo-Interface 1", "internal": true, "mac": "00:00:00:00:00:00", "address": "::1", "netmask": "ffff:ffff:ffff:ffff:ffff:ffff:ffff:ffff", "family": "IPv6", "scopeid": 0 }, { "name": "Loopback Pseudo-Interface 1", "internal": true, "mac": "00:00:00:00:00:00", "address": "127.0.0.1", "netmask": "255.0.0.0", "family": "IPv4" } ], "host": "csworen-mobl1" }, "javascriptStack": { "message": "No stack.", "stack": [ "Unavailable." ], "errorProperties": { } }, "javascriptHeap": { "totalMemory": 1729368064, "totalCommittedMemory": 1729368064, "usedMemory": 1539078096, "availableMemory": 2208273816, "memoryLimit": 3917479936, "heapSpaces": { "read_only_space": { "memorySize": 139264, "committedMemory": 139264, "capacity": 127292, "used": 127292, "available": 0 }, "old_space": { "memorySize": 1441984512, "committedMemory": 1441984512, "capacity": 1280304304, "used": 1280056088, "available": 248216 }, "code_space": { "memorySize": 20799488, "committedMemory": 20799488, "capacity": 14030368, "used": 14030368, "available": 0 }, "map_space": { "memorySize": 2895872, "committedMemory": 2895872, "capacity": 1762720, "used": 1762720, "available": 0 }, "large_object_space": { "memorySize": 246222848, "committedMemory": 246222848, "capacity": 242595996, "used": 242595996, "available": 0 }, "code_large_object_space": { "memorySize": 548864, "committedMemory": 548864, "capacity": 505632, "used": 505632, "available": 0 }, "new_large_object_space": { "memorySize": 0, "committedMemory": 0, "capacity": 8121856, "used": 0, "available": 8121856 }, "new_space": { "memorySize": 16777216, "committedMemory": 16777216, "capacity": 8121856, "used": 0, "available": 8121856 } } }, "nativeStack": [ ], "resourceUsage": { "userCpuSeconds": 85.296, "kernelCpuSeconds": 12.531, "cpuConsumptionPercent": 134.01, "maxRss": 1925529600, "pageFaults": { "IORequired": 874282, "IONotRequired": 0 }, "fsActivity": { "reads": 15175, "writes": 531 } }, "libuv": [ { "type": "async", "is_active": true, "is_referenced": false, "address": "0x0000000003f619d8" }, { "type": "async", "is_active": true, "is_referenced": false, "address": "0x00000000035cfeb0" }, { "type": "timer", "is_active": true, "is_referenced": true, "address": "0x00000000065a2dc8", "repeat": 0, "firesInMsFromNow": 32, "expired": false }, { "type": "check", "is_active": true, "is_referenced": false, "address": "0x00000000065a2e28" }, { "type": "idle", "is_active": true, "is_referenced": true, "address": "0x00000000065a2e64" }, { "type": "prepare", "is_active": true, "is_referenced": false, "address": "0x00000000065a2ea0" }, { "type": "check", "is_active": true, "is_referenced": false, "address": "0x00000000065a2edc" }, { "type": "async", "is_active": true, "is_referenced": false, "address": "0x00000000065a2f18" }, { "type": "async", "is_active": true, "is_referenced": false, "address": "0x00000000035cfe10" }, { "type": "tty", "is_active": false, "is_referenced": true, "address": "0x00000000066aca78", "width": 235, "height": 17, "writeQueueSize": 0, "readable": false, "writable": true }, { "type": "signal", "is_active": true, "is_referenced": false, "address": "0x0000000006875b70", "signum": 28, "signal": "SIGWINCH" }, { "type": "tty", "is_active": false, "is_referenced": true, "address": "0x00000000066a7f90", "width": 235, "height": 17, "writeQueueSize": 0, "readable": false, "writable": true }, { "type": "tty", "is_active": false, "is_referenced": true, "address": "0x00000000066b2638", "writeQueueSize": 0, "readable": true, "writable": false }, { "type": "signal", "is_active": true, "is_referenced": false, "address": "0x000000000673a8f0", "signum": 2, "signal": "SIGINT" }, { "type": "signal", "is_active": true, "is_referenced": false, "address": "0x000000000673a9c0", "signum": 15, "signal": "SIGTERM" }, { "type": "tcp", "is_active": true, "is_referenced": true, "address": "0x00000000071c7d98", "localEndpoint": { "host": "csworen-mobl1.amr.corp.intel.com", "port": 4200 }, "remoteEndpoint": null, "sendBufferSize": 65536, "recvBufferSize": 65536, "writeQueueSize": 0, "readable": false, "writable": false }, { "type": "pipe", "is_active": false, "is_referenced": false, "address": "0x0000000044746030", "localEndpoint": null, "remoteEndpoint": "\\\\?\\pipe\\uv\\FFFFFFFF-23116", "writeQueueSize": 0, "readable": true, "writable": true }, { "type": "pipe", "is_active": true, "is_referenced": false, "address": "0x0000000044745270", "localEndpoint": null, "remoteEndpoint": "\\\\?\\pipe\\uv\\00000000-23116", "writeQueueSize": 0, "readable": true, "writable": true }, { "type": "process", "is_active": true, "is_referenced": false, "address": "0x0000000003f8a3a0", "pid": 13924 }, { "type": "timer", "is_active": true, "is_referenced": false, "address": "0x0000000003ff7b78", "repeat": 0, "firesInMsFromNow": 3441, "expired": false }, { "type": "loop", "is_active": true, "address": "0x0000000003859c90", "loopIdleTimeSeconds": 0.0058206 } ], "workers": [ ], "environmentVariables": { "=C:": "C:\\Users\\csworen\\source\\repos\\Commits\\UI", "ALLUSERSPROFILE": "C:\\ProgramData", "APPDATA": "C:\\Users\\csworen\\AppData\\Roaming", "ATERNITY_AGENT_HOME": "C:\\Program Files (x86)\\Aternity Information Systems\\Agent\\", "BROWSERSLIST_IGNORE_OLD_DATA": "1", "CHROME_CRASHPAD_PIPE_NAME": "\\\\.\\pipe\\crashpad_2500_ONGTCPGFDBVGORDW", "COLOR": "1", "COLORTERM": "truecolor", "CommonProgramFiles": "C:\\Program Files (x86)\\Common Files", "CommonProgramFiles(x86)": "C:\\Program Files (x86)\\Common Files", "CommonProgramW6432": "C:\\Program Files\\Common Files", "COMPUTERNAME": "CSWOREN-MOBL1", "ComSpec": "C:\\windows\\system32\\cmd.exe", "DriverData": "C:\\Windows\\System32\\Drivers\\DriverData", "EDITOR": "notepad.exe", "FPS_BROWSER_APP_PROFILE_STRING": "Internet Explorer", "FPS_BROWSER_USER_PROFILE_STRING": "Default", "GIT_ASKPASS": "c:\\Users\\csworen\\AppData\\Local\\Programs\\Microsoft VS Code\\resources\\app\\extensions\\git\\dist\\askpass.sh", "HOME": "C:\\Users\\csworen", "HOMEDRIVE": "C:", "HOMEPATH": "\\Users\\csworen", "INIT_CWD": "C:\\Users\\csworen\\source\\repos\\Commits\\UI", "Intellogs": "C:\\Intel\\Logs", "LANG": "en_US.UTF-8", "LOCALAPPDATA": "C:\\Users\\csworen\\AppData\\Local", "LOGONSERVER": "\\\\ORSAMR606", "NODE": "C:\\Program Files (x86)\\nodejs\\node.exe", "NODE_EXE": "C:\\Program Files (x86)\\nodejs\\\\node.exe", "NPM_CLI_JS": "C:\\Users\\csworen\\AppData\\Roaming\\npm\\node_modules\\npm\\bin\\npm-cli.js", "npm_command": "start", "npm_config_cache": "C:\\Users\\csworen\\AppData\\Local\\npm-cache", "npm_config_email": "chris.sworen@intel.com", "npm_config_globalconfig": "C:\\Users\\csworen\\AppData\\Roaming\\npm\\etc\\npmrc", "npm_config_global_prefix": "C:\\Users\\csworen\\AppData\\Roaming\\npm", "npm_config_init_module": "C:\\Users\\csworen\\.npm-init.js", "npm_config_local_prefix": "C:\\Users\\csworen\\source\\repos\\Commits\\UI", "npm_config_metrics_registry": "https://registry.npmjs.org/", "npm_config_node_gyp": "C:\\Users\\csworen\\AppData\\Roaming\\npm\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js", "npm_config_noproxy": "", "npm_config_prefix": "C:\\Users\\csworen\\AppData\\Roaming\\npm", "npm_config_userconfig": "C:\\Users\\csworen\\.npmrc", "npm_config_user_agent": "npm/8.1.4 node/v16.13.0 win32 ia32 workspaces/false", "npm_execpath": "C:\\Users\\csworen\\AppData\\Roaming\\npm\\node_modules\\npm\\bin\\npm-cli.js", "npm_lifecycle_event": "start", "npm_lifecycle_script": "node --max_old_space_size=16000 --report-on-fatalerror node_modules/@angular/cli/bin/ng s", "npm_node_execpath": "C:\\Program Files (x86)\\nodejs\\node.exe", "npm_package_json": "C:\\Users\\csworen\\source\\repos\\Commits\\UI\\package.json", "npm_package_name": "commits", "NPM_PREFIX_NPM_CLI_JS": "C:\\Users\\csworen\\AppData\\Roaming\\npm\\node_modules\\npm\\bin\\npm-cli.js", "NUMBER_OF_PROCESSORS": "8", "OneDrive": "C:\\Users\\csworen\\OneDrive - Intel Corporation", "OneDriveCommercial": "C:\\Users\\csworen\\OneDrive - Intel Corporation", "ORIGINAL_XDG_CURRENT_DESKTOP": "undefined", "OS": "Windows_NT", "Path": "C:\\Users\\csworen\\source\\repos\\Commits\\UI\\node_modules\\.bin;C:\\Users\\csworen\\source\\repos\\Commits\\node_modules\\.bin;C:\\Users\\csworen\\source\\repos\\node_modules\\.bin;C:\\Users\\csworen\\source\\node_modules\\.bin;C:\\Users\\csworen\\node_modules\\.bin;C:\\Users\\node_modules\\.bin;C:\\node_modules\\.bin;C:\\Users\\csworen\\AppData\\Roaming\\npm\\node_modules\\npm\\node_modules\\@npmcli\\run-script\\lib\\node-gyp-bin;C:\\Oracle11gR2_x32\\product\\11.2.0\\client_1\\bin;C:\\app\\csworen\\product\\19.0.0\\client_1;C:\\Program Files (x86)\\Microsoft SDKs\\Azure\\CLI2\\wbin;C:\\windows\\system32;C:\\windows;C:\\windows\\System32\\Wbem;C:\\windows\\System32\\WindowsPowerShell\\v1.0\\;C:\\windows\\System32\\OpenSSH\\;C:\\Program Files (x86)\\Microsoft SQL Server\\150\\DTS\\Binn\\;C:\\Program Files\\Azure Data Studio\\bin;C:\\Program Files\\Microsoft SQL Server\\130\\Tools\\Binn\\;C:\\Program Files\\Microsoft SQL Server\\Client SDK\\ODBC\\170\\Tools\\Binn\\;C:\\Program Files (x86)\\PuTTY\\;C:\\Program Files (x86)\\nodejs\\;C:\\Program Files\\Git\\cmd;C:\\Program Files (x86)\\Microsoft SQL Server\\110\\DTS\\Binn\\;C:\\Program Files (x86)\\Microsoft SQL Server\\120\\DTS\\Binn\\;C:\\Program Files (x86)\\Microsoft SQL Server\\130\\DTS\\Binn\\;C:\\Program Files (x86)\\Microsoft SQL Server\\140\\DTS\\Binn\\;C:\\Program Files\\dotnet\\;C:\\Users\\csworen\\AppData\\Local\\Microsoft\\WindowsApps;;C:\\Users\\csworen\\AppData\\Local\\Programs\\Microsoft VS Code\\bin;C:\\Program Files\\Azure Data Studio\\bin;C:\\Users\\csworen\\AppData\\Roaming\\npm;C:\\Users\\csworen\\.dotnet\\tools", "PATHEXT": ".COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC;.CPL", "PROCESSOR_ARCHITECTURE": "x86", "PROCESSOR_ARCHITEW6432": "AMD64", "PROCESSOR_IDENTIFIER": "Intel64 Family 6 Model 140 Stepping 1, GenuineIntel", "PROCESSOR_LEVEL": "6", "PROCESSOR_REVISION": "8c01", "ProgramData": "C:\\ProgramData", "ProgramFiles": "C:\\Program Files (x86)", "ProgramFiles(x86)": "C:\\Program Files (x86)", "ProgramW6432": "C:\\Program Files", "PROMPT": "$P$G", "PSModulePath": "C:\\Users\\csworen\\OneDrive - Intel Corporation\\Documents\\WindowsPowerShell\\Modules;C:\\Program Files\\WindowsPowerShell\\Modules;C:\\windows\\system32\\WindowsPowerShell\\v1.0\\Modules", "PUBLIC": "C:\\Users\\Public", "SESSIONNAME": "Console", "STEELCENTRAL_ATERNITY_AGENT_HOME": "C:\\Program Files (x86)\\Aternity Information Systems\\Agent\\", "SystemDrive": "C:", "SystemRoot": "C:\\windows", "TEMP": "C:\\Users\\csworen\\AppData\\Local\\Temp", "TERM_PROGRAM": "vscode", "TERM_PROGRAM_VERSION": "1.66.1", "TMP": "C:\\Users\\csworen\\AppData\\Local\\Temp", "UATDATA": "C:\\windows\\CCM\\UATData\\D9F8C395-CAB8-491d-B8AC-179A1FE1BE77", "USERDNSDOMAIN": "AMR.CORP.INTEL.COM", "USERDOMAIN": "AMR", "USERDOMAIN_ROAMINGPROFILE": "AMR", "USERNAME": "csworen", "USERPROFILE": "C:\\Users\\csworen", "VSCODE_GIT_ASKPASS_EXTRA_ARGS": "--ms-enable-electron-run-as-node", "VSCODE_GIT_ASKPASS_MAIN": "c:\\Users\\csworen\\AppData\\Local\\Programs\\Microsoft VS Code\\resources\\app\\extensions\\git\\dist\\askpass-main.js", "VSCODE_GIT_ASKPASS_NODE": "C:\\Users\\csworen\\AppData\\Local\\Programs\\Microsoft VS Code\\Code.exe", "VSCODE_GIT_IPC_HANDLE": "\\\\.\\pipe\\vscode-git-37edf79619-sock", "WEBPACK_SERVE": "true", "windir": "C:\\windows", "ZES_ENABLE_SYSMAN": "1", "_JAVA_OPTIONS": "-Djava.net.preferIPv4Stack=true" }, "sharedObjects": [ "C:\\Program Files (x86)\\nodejs\\node.exe", "C:\\windows\\SYSTEM32\\ntdll.dll", "C:\\windows\\System32\\KERNEL32.DLL", "C:\\windows\\System32\\KERNELBASE.dll", "C:\\windows\\System32\\WS2_32.dll", "C:\\windows\\System32\\RPCRT4.dll", "C:\\windows\\SYSTEM32\\dbghelp.dll", "C:\\windows\\System32\\PSAPI.DLL", "C:\\windows\\System32\\ucrtbase.dll", "C:\\windows\\System32\\ADVAPI32.dll", "C:\\windows\\System32\\msvcrt.dll", "C:\\windows\\SYSTEM32\\USERENV.dll", "C:\\windows\\System32\\sechost.dll", "C:\\windows\\SYSTEM32\\IPHLPAPI.DLL", "C:\\windows\\System32\\USER32.dll", "C:\\windows\\System32\\win32u.dll", "C:\\windows\\System32\\GDI32.dll", "C:\\windows\\System32\\gdi32full.dll", "C:\\windows\\System32\\msvcp_win.dll", "C:\\windows\\System32\\CRYPT32.dll", "C:\\windows\\System32\\bcrypt.dll", "C:\\windows\\SYSTEM32\\WINMM.dll", "C:\\windows\\SYSTEM32\\CRYPTBASE.DLL", "C:\\windows\\System32\\IMM32.DLL", "C:\\windows\\SYSTEM32\\powrprof.dll", "C:\\windows\\SYSTEM32\\UMPDC.dll", "C:\\windows\\system32\\uxtheme.dll", "C:\\windows\\System32\\combase.dll", "C:\\windows\\system32\\mswsock.dll", "C:\\windows\\SYSTEM32\\kernel.appcore.dll", "C:\\windows\\System32\\bcryptprimitives.dll", "C:\\windows\\System32\\NSI.dll", "C:\\windows\\SYSTEM32\\dhcpcsvc6.DLL", "C:\\windows\\SYSTEM32\\dhcpcsvc.DLL", "C:\\windows\\SYSTEM32\\DNSAPI.dll", "C:\\Windows\\System32\\rasadhlp.dll", "C:\\windows\\System32\\fwpuclnt.dll", "C:\\windows\\system32\\napinsp.dll", "C:\\windows\\system32\\pnrpnsp.dll", "C:\\windows\\system32\\wshbth.dll", "C:\\windows\\system32\\NLAapi.dll", "C:\\windows\\System32\\winrnr.dll" ] }
Here's my start script:
"start": "node --max_old_space_size=40000 --report-on-fatalerror node_modules/@angular/cli/bin/ng s",
To clarify, downgrading Node/NPM was half of the answer. With updating properly (some packages needed to be tweaked for versioning), I can now run locally with "ng s -o" and our build on Azure is going swimmingly. I have a coworker to thank for the tedious portion of figuring out which packages needed realignment.
Thank you for your assistance.
Hello Chris,
Thank you for your update on this matter. I will continue to monitor this thread and await your next update on if a different LTS and Node / NPM environment helps you in this case.
I am running "npm start" in my local environment and not getting anywhere with it.
I'm wondering if it's because I'm on Node 16.x and NPM 8.x. I am downgrading to the LTS for Node 14 to see if it performs better.
I just wanted to confirm a couple of things in this case, as it doesn’t make a lot of sense to me that your machine sounds quite a bit more powerful than the one I am testing on, but yet I am able to run the sample I sent you. Can you confirm the following?
1. When you say it does not serve on your system, is this to say you are trying to run the sample locally or in an Azure environment?
2. What is the NPM command you are running to try to run the sample. I am curious if perhaps you are calling ng serve, as this will use the default space size for the application. You will need to run npm run start in order to have the max_old_space_size flag applied in the sample project I sent you.
It does not serve on my system. At 12GB (which you provided), I got these error messages:
<--- Last few GCs ---> [24736:04463BF0] 68031 ms: Mark-sweep (reduce) 1590.3 (1667.0) -> 1468.3 (1626.3) MB, 3131.7 / 0.0 ms (average mu = 0.904, current mu = 0.914) last resort GC in old space requested [24736:04463BF0] 71474 ms: Mark-sweep (reduce) 1468.3 (1626.3) -> 1466.3 (1565.8) MB, 3443.7 / 0.0 ms (average mu = 0.789, current mu = 0.000) last resort GC in old space requested <--- JS stacktrace ---> FATAL ERROR: CALL_AND_RETRY_LAST Allocation failed - JavaScript heap out of memory
In multiples of 8gb (and other random values), I get the same unhelpful errors as before:
Anything above 12gb that does not throw the useless error above stops processing at the phase:building step of generating browser bundles. Either it hangs there forever or it just ends the process without any indicator of why:
**************************************************************************************** This is a simple server for use in testing or debugging Angular applications locally. It hasn't been reviewed for security issues. DON'T USE IT FOR PRODUCTION! **************************************************************************************** ⠋ Generating browser application bundles (phase: building)...
You are correct in assuming it is not complex enough to run in Azure environments. Azure requires terraform scripts to facilitate the build, config files that include your subscription and specific app landing zones, and/or configurations for a VM if you are using one. Additionally, our systems require the use of MSAL to utilize single sign-on.
