I am using 13.2 IG/AG.
Is there a way to dynamically allocate space in an Input (width and multiple rows) depending on how long the content is expected to be? If not, is there a text area object that I'm not seeing in the component library?
I have an Input (at present) that has an average text size of about 96 characters. Since it's in a modal-dialog, I'd definitely prefer it to be taller rather than wide enough to blot out the entire screen behind it (as it would require and not even show everything for users with narrow screens).
Here is my current code for it:
<igx-input-group displayDensity="compact"> <igx-prefix>Answer: </igx-prefix> <input igxInput style="width: 600px" id="answer" type="text" [(ngModel)]="editFaq.answer" (ngModelChange)="answerChanged.next($event)" /> </igx-input-group>
Thanks in advance!
I am glad that you find my suggestion helpful. Thank you for using Infragistics components!
Best regards
Thanks, that works well.
Hello Chris,
Thank you for posting to Infragistics Community!
I have been looking into your question and determined that there is currently no possibility to put multiple rows in igxInput field. My suggestion for achieving your requirement is to use a <textarea> element with igxInput directive. This will work according to your requirements and in your modal-dialog you will be able to set as many rows as you need without having to increase the width.
In addition, I have prepared a small sample illustrating my suggestion which could be found here.
Please test it on your side and let me know how it behaves.
If you require any further assistance on the matter, please let me know.
Software Developer
