Facing a lot of issue while working with column chart how to fix the column width and space between them if the data exceed need to add scroll
showing like this need to show it like this one
1. The gap properties should allow you to add spacing between the columns.
eg.
www.infragistics.com/.../chart-axis-options
2. The windowRect property will allow you to set a zoom level so that scrolling can be enabled on startup.
www.infragistics.com/.../chart-navigation
