I would like to scroll a per code selected row into view, so that it could be seen by the user.Is this possible?
Thank you in advance,Klaus
This code worked great to go to a specific record. It always bring it to the top of the visible grid. However, if the row contains a boolean checkbox and all you want to do is change its values -- the action to click the box shifts the row to the top of the visible grid -- and the subsequent click to change the value of the checkbow ends up changing the checkbox of a different row. Is there a way to not navigate to the row if the row is already in the visible portion of the gid?
Ted Herrlich said:I was wondering how to make this navigation work for a paginated grid if the record is not on the currently visible page?
I have the same question. papa's burgeria
HI,
Georgi, Great answer, thank you very much
Hello Klaus,
I am glad that you find my suggestion helpful.
