220
Igx-grid: Batch editing on igx-select
Hello, I have an igx grid with Excel filtering and batch editing active. One of the columns contains an igx-select from which the user can select a value.
When I filter this column (that contains an igx-select element), then change a value from the shown filtered list, and then undo those changes, the new value I selected from the igx-select list is not reverted, but assigned to a different row. And I only want to undo the changes.
When I edit a value of another column (that does not have a igx-select) the value is set up correctly. and the undo action also works fine. So I assume the problem is in the igx-select. Is it possible to use the igx-select on a filtered list and to undo the changed value correctly?
Here are my redo and undo buttons
  <div class="buttons-wrapper">
      <button igxButton style="margin-top: 40px; margin-left: 0px;" [disabled]="!grid1.transactions.canUndo" (click)="undo()">
        <igx-icon>undo</igx-icon>
      </button>
      <button igxButton style="margin-left: 0px;" [disabled]="!grid1.transactions.canRedo" (click)="redo()">
        <igx-icon>redo</igx-icon>
      </button>
    </div>
This is my igx-grid:
<igx-grid igxPreventDocumentScroll
            #grid1
            igxOverlayOutlet
            [height]="'97%'"
            width="99%"
            [pinnedColumnsText]="'pinned'"
            [batchEditing]="true"
            [autoGenerate]='false'
            [data]="sqlData"
            [primaryKey]="'lot'"
            [showToolbar]="true"
            [allowFiltering]="true"
            [columnHiding]="true"
            [rowHeight]="20"
            filterMode="excelStyleFilter"
            (cellEditDone)="cellEditDoneHandler($event)"
            (activeNodeChange)="handleChange()"
            [clipboardOptions]="copyOptions">
    <igx-column width="120px" field="department" dataType="string" header="Department" [resizable]="true" [editable]="false" [sortable]="true" [movable]="true" [cellClasses]="greenRowLotClass">
      <ng-template igxCell let-cell="cell" let-val>
        <div [ngClass]="[cell.row.deleted?'upfont' : 'drop-down-grid']">
          <igx-select #selectDepartment
                      placeholder="Wähle Abteilung"
                      [overlaySettings]="overlaySettings"
                      [(ngModel)]="cell.value">
            <igx-select-item style="font-size: 12px;" *ngFor="let item of dropDownDepartmentAdmin" [value]="item">
              {{ item }}
            </igx-select-item>
          </igx-select>
        </div>
      </ng-template>
      <ng-template igxCell let-cell="cell">
        <div [ngClass]="[cell.row.deleted?'upfont' : 'text-cell']">{{cell.value}}</div>
        <button class="action-button" [ngClass]="[cell.row.deleted?'grey-button-deleted-row' : 'black-button-edit-cell']" igxButton="icon" [disabled]="cell.row.deleted" (click)="editSelectedData(cell.id.rowID,cell.column.field, cell.value)">
          <igx-icon class="action-icon">edit</igx-icon>
        </button>
      </ng-template>
    </igx-column>
  </igx-grid>
And here are my undo and redo functions in the .ts file:
  public undo() {
    this.grid1.endEdit(true);
    this.grid1.transactions.undo();
  public redo() {
    this.grid1.transactions.redo();
I hope you can help me. Thank you.
