I would like to use the igx-grid-toolbar-pinning component so that the user can manually select which columns they'd like pinned. This almost works perfectly except that the grid has hidden columns that shouldn't appear in the list of options. Is there a way that the list can be changed to only show unhidden columns?
Thanks!
I have been looking into your question and an approach I could suggest is to use the columns' disablePinning property and set it depending on the column's hidden state. This way the columns with disabled pinning would not be displayed in the pinning list.
In order to calculate which columns should be displayed initially, my suggestion is to handle the grid's columnInit event and if you are changing the visibility of the columns runtime - columnVisibilityChanged event.
A small sample that demonstrates my suggestion could be found here.
Please test it on your side and let me know if I may be of any further assistance.Sincerely,Teodosia HristodorovaSoftware Developer
