370
Angular Grid Row Editing multiple fields in same column
I have a requirement where I have a single column "Sort" which has two separate Fields "Position" and "Direction". Is it possible to use cell.editValue.Position and cell.editValue.Direction which also submits the Cancel/Done options in grid editing. This somehow does not work for me.
<igx-column field="Sort" header="Sort" [dataType]="'number'">
<ng-template igxCellEditor let-cell="cell">
<igx-input-group>
<input igxInput [igxFocus]='true' name="units" [(ngModel)]="cell.editValue.Position" style="color: black" />
</igx-input-group>
<igx-input-group>
<input igxInput [igxFocus]='true' name="units" [(ngModel)]="cell.editValue.Direction" style="color: black" />
</igx-input-group>
</ng-template>
</igx-column>
    If you are seeking Lodhi Road Escort, then your search ends here! Our premium call girl services offer high-class escorts who accept cash payments discreetly and securely, providing a vast selection of beautiful girls perfect for keeping you company on lonely nights, with convenient 24/7 doorstep deliveries available.
  • 740
    Hello Shahab,
    Thank you for posting in our community!
    I have been looking into your question and to ensure that it is addressed correctly, I need to ask for some additional information.
    Could you please clarify if the attached screenshot represents the desired outcome?
    Also, you have mentioned: Is it possible to use cell.editValue.Position and cell.editValue.Direction which also submits the Cancel/Done options in grid editing.
    Could you please elaborate further on the “also submits the Cancel/Done options in grid editing” part of the requirement? Do you mean that the edit values should be submitted/disregarded when clicking the Done/Cancel button?
    It is possible to submit the values when editing the column by using the configuration that you have provided since the IgxGrid supports Complex Data Binding. If you require using the IgxSelect component, I could suggest templating it insite the ng-template and binding it in a similar manner as the provided code snippet. Also, I believe that you will find the following topic here quite helpful on the matter.
    However, if you require a configuration that is similar to the one in the attached screenshot and you do not use row/cell editing, I would suggest using the igxCell template directive instead again with the IgxSelect component.
    Nevertheless, if these suggestions are not an accurate demonstration of what you are trying to achieve, answering the abovemetioned questions and providing any additional information on the exact requirements will be extremely helpful in further investigating this matter and providing you with a solution as soon as possible.
    Thank you for your cooperation. Looking forward to your reply.
    Sincerely,
    Riva Ivanova
    Software Developer
