Hi ,
We are using Angular igx-grid. if the column length exceeds certain limit by default Grid adds ... towards the end and shows the full text as part of tool tip.
can we customize this feature like keeping an icon instead of ... and clicking on the icon opens kinda of dialog or overlay so user have the flexibility to read the full text t
Thanks for answering, my issue is resolved now. Please mark it as solution.
Yes, you can customize the Angular igx-grid to show an icon instead of the default ellipsis (...) and display the full text in a dialogue or overlay when the icon is clicked. To achieve this, you must create a custom cell template for the grid column and use Angular's material dialogue or an overlay component. Here’s a high-level approach:
igx-grid
Create a Custom Cell Template: Define a custom cell template for the columns where you want to show the icon.
Add the Icon: Use an icon (e.g., a magnifying glass or info icon) in the custom cell template.
Implement the Click Event: Attach a click event to the icon that opens a dialogue or overlay containing the full text.
Use Angular Material Dialog: Use Angular Material’s MatDialog to create a dialogue that displays the full text.
MatDialog
Here’s a simplified example:
<igx-column field="yourField"> <ng-template igxCell let-cell="cell"> <div> <span>{{ cell.value | slice:0:20 }}</span> <mat-icon (click)="openDialog(cell.value)">info</mat-icon> </div> </ng-template> </igx-column>
In your component:
import { MatDialog } from '@angular/material/dialog'; import { Component } from '@angular/core'; @Component({ // Component metadata }) export class YourComponent { constructor(public dialog: MatDialog) {} openDialog(value: string): void { this.dialog.open(DialogContentComponent, { data: { fullText: value } }); } }
Create a separate component for the dialogue content:
import { MAT_DIALOG_DATA } from '@angular/material/dialog'; import { Inject } from '@angular/core'; @Component({ selector: 'dialog-content', template: '<p>{{ data.fullText }}</p>', }) export class DialogContentComponent { constructor(@Inject(MAT_DIALOG_DATA) public data: { fullText: string }) {} }
This setup allows you to replace the ellipsis with an icon that opens a dialogue displaying the full text, giving users the flexibility to read it easily.
Here is a bonus for developers like you. This is a modern Instagram just like GB whatsapp to normal Whatsapp, this is the Instander to normal Instagram. This APK has many more features and customizable developer options that allow you to create your own features of interest on Instagram.
I have been looking into your question and let’s customize the igx-grid cells instead of the headers to replace the default ellipsis (...) with an icon. Clicking the icon will open a dialog to display the full cell text.
Steps to Customize igx-grid Cells
<ng-template igxCell let-cell="cell"> <div class="cell-content"> <!-- Display first two words and an icon for longer cell texts --> <span *ngIf="cell.value.length > maxLength"> {{ getFirstTwoWords(cell.value) }} <igx-icon family="material" (click)="openDialog(cell.value)">more</igx-icon> </span> <!-- Display full cell text if it's short enough --> <span *ngIf="cell.value.length <= maxLength">{{ cell.value }}</span> </div> </ng-template>
<igx-dialog #dialog> <igx-dialog-title>Full Text</igx-dialog-title> <div>{{ fullText }}</div> <igx-dialog-actions> <button igxButton="contained" (click)="closeDialog()">Close</button> </igx-dialog-actions> </igx-dialog>
@ViewChild('dialog', { static: true }) public dialog: IgxDialogComponent; public data: any[]; public maxLength = 10; // Maximum length for header text before truncation public fullText = ''; constructor() {} ngOnInit() { // Initialize data this.data = DATA; } // Method to get the first two words of a string public getFirstTwoWords(text: string): string { return text.split(' ').slice(0, 2).join(' '); } // Method to open the dialog with the full header text public openDialog(text: string) { this.fullText = text; this.dialog.open(); } // Method to close the dialog public closeDialog() { this.dialog.close(); }
Key Points
This approach allows you to customize the cell content to show an icon instead of ellipsis (...).
The described scenario could be observed here:
In addition, I have prepared small sample illustrating this behavior which could be found here. Please test it on your side and let me know how it behaves.
If you require any further assistance on the matter, please let me know.
hey , thanks for the update .
sorry as my question is not clear
basically my problem is with data exceeding the length and not columns , can you give some examples for the grid data
may be an icon or ellipsis that can be clickable with similar experience what you have show n for column headers
I have been looking into your question and to customize the igx-grid column headers and display an icon instead of the default ellipsis (...), you can implement the following steps. This will allow users to click the icon to open a dialog displaying the full text of the column header.
Steps to Customize igx-grid Column Headers
<ng-template igxHeader let-column> <div class="header-content"> <!-- Display first two words and an icon for longer headers --> <span *ngIf="column.header.length > maxLength"> {{ getFirstTwoWords(column.header) }} <igx-icon family="material" (click)="openDialog(column.header)">more</igx-icon> </span> <!-- Display full header if it's short enough --> <span *ngIf="column.header.length <= maxLength">{{ column.header }}</span> </div> </ng-template>
<!-- Dialog to show full header text --> <igx-dialog #dialog> <igx-dialog-title>Full Header Text</igx-dialog-title> <div>{{ fullText }}</div> <igx-dialog-actions> <button igxButton="contained" (click)="closeDialog()">Close</button> </igx-dialog-actions> </igx-dialog>
