Adding steps down below to reproduce it.
1. Created an editable grid with Excel Style Filtering applied.
<igx-grid height="700px" [data]="testData" [allowFiltering]="true" [filterMode]="'excelStyleFilter'"> <igx-column field="column1" header="Column 1" dataType="string" [editable]="true"> </igx-column> </igx-grid>
2. Opening 'Column 1' filtering menu and deselecting blanks. Pressing 'Apply'
3. Editing 'Column 1' cell value for example from 'Test-A' to 'Test-B'. Pressing Enter.
4. Edited cell row disappears and new cell value won't be selected in column filter.
Expected result:
Row won't disappear and new cell value will be selected in filter as only blanks were filtered out.
How to solve it?
After an investigation, I have determined that this behavior is observed because the filtering is updated and the new value was not previously provided, so it is not selected in the searchValue set. What I could suggest is to add the new value in the filtering expression. This could be achieved in a method bound to the cellEditDone event as follows:
public editDone(evt) {
const column = evt.column.field;
const newValue = evt.newValue;
if (column === 'QuantityPerUnit') {
// Get the current filter criteria for the Quantity column
const filters = this.grid1.filteringExpressionsTree.find(column) as FilteringExpressionsTree;
const excludedValues = this.grid1.data
.filter((value) => !this.grid1.filteredData.includes(value))
.map((row) => row['QuantityPerUnit']);
if (!excludedValues.includes(newValue)) {
const newExpression: IFilteringExpression = {
fieldName: column,
searchVal: newValue,
condition: IgxStringFilteringOperand.instance().condition('equals'),
filters.filteringOperands.push(newExpression);
I have prepared a sample, demonstrating the described behavior, please test it on your side and let me know if you need any further information regarding this matter.
Regards, Monika Kirkova, Infragistics
