95
IgxDataChartComponent: how to fix x axis width
I have been requested to make a series of data charts starting at the same X to have the same width, so that all the intervals coincide visually (they're placed one below the other). It's of course possible to fix the width of the IgxChartComponent itself, but this won't do because these charts contain different vertical axes (one might contain one vertical axis, another might contain three) and there is no way to control the width of the actual chart rendered in the canvas (at least as far as I know).
I have tried the rather awkward approach of adding supplemental vertical axis rendered in white, so that the actual rendered charts match visually. As a brute-force approach as it may seem it works... until I hover on the chart with the most vertical axes, the crosshairs and the axis annotations get rendered... and the axes become slighty wider, thus causing the charts to be misaligned.
Any suggestion as to how to achieve this effect will be much appreciated.
Kind regards
