At times, the data that I am showing in a grid comes from a result set with a 2 part key.
For example, I might be showing total qty on hand by color and size.
This allows my user to group or filter the data to provide the info that they are looking for.
But I also need to be able to select rows so that I can create a subsequent query with just the sets of colors+sizes selected.
I believe I need a primaryKey for this and for several other grid features.
How do I set the primary key to a combination of fields?
Thank you for sharing your thoughts on this potential enhancement. Your request to define composite key columns directly within the grid would indeed make the process more efficient by removing the need for data preprocessing, especially with larger datasets. However, as this feature is not currently available, I’d like to confirm that this requirement is considered a feature request.
At this stage, it’s beyond my scope to determine if or when such functionality might be implemented in our grid, but our development team will carefully review it. To formally submit your request, I recommend creating a feature request in our Ignite UI Angular GitHub repository. This will allow our team to examine your suggestion, assess its applicability to the broader user base, and determine if it would be a valuable enhancement for the grid.
Here’s how you can create your feature request:
To strengthen your proposal, consider describing:
This feature request submission will enable you to communicate directly with our development team, and you’ll receive updates whenever there’s new information on the feature’s status.
Thank you again for your suggestion, and please let me know if you need further assistance!
Georgi,
Thanks for the explanation.
But I think it would me a welcome improvement if I could specify the columns that make up a composite key.
This would relieve me of the performance hit I would incur by traversing my data array, and side effects of adding another property to each data object.
I believe that the grid must be traversing and hashing the data array with a single, simple, key (if specified). So why not traverse and hash the data array in a way that assembles the composite key from the list of columns that I specify as key elements?
I know that this question has now morphed into a feature request, and you have answered my original question, so I am marking your answer as verified.
I understand you’d like to use a combination of fields, like color and size, as a unique key in the Ignite UI Angular grid to enable features such as grouping, filtering, and row selection. Here’s some context on why a primary key is required and why, by default, it’s typically a single unique identifier.
Importance of a Unique, Single Identifier as Primary Key
In most data-driven applications, including Ignite UI Angular grid components, the primary key is designed to be a single, unique identifier. This standard is essential because it enables the grid to locate, manage, and track each row efficiently, ensuring seamless performance and data integrity. When a primary key is unique and singular, the grid can handle operations like selection, filtering, and grouping precisely, without having to manage complex combinations or check for ambiguities.
Why the Grid Prefers Single-Field Primary Keys
The Ignite UI Angular grid is optimized to use a single, unique field as the primaryKey. A single primary key allows the grid to quickly locate specific rows and track their state, which is essential for performance, especially with larger datasets. This approach prevents the need to recalculate unique combinations on every interaction, ensuring smooth performance and reliable data handling.
Solution: Implementing a Composite Key for Color and Size
To achieve the required functionality with your color and size combination, we can create a composite key by adding a new field to your data that combines these two properties. Here’s how it would work:
Here’s an example of how this setup would look in your data and grid configuration:
data.forEach(item => {
item.compositeKey = `${item.color}_${item.size}`;
In the grid configuration:
<igx-grid [data]="data" primaryKey="compositeKey" ...> </igx-grid>
This approach still relies on the principle of a single, unique identifier. By creating a composite key field, we adhere to the primary key requirement while representing both color and size together in a unique way. It’s important to note that this solution is a workaround tailored to meet your specific needs rather than a widely practiced method. In most scenarios, using a single, pre-existing unique identifier remains the best practice to ensure optimized performance and alignment with standard data management principles.
Conclusion
In summary, while creating a composite field to act as a primary key can work for your requirements, it does come with some considerations. Since this is a customized approach rather than a conventional one, it may require extra steps in data preparation and maintenance, especially if the structure of color and size values changes over time.
If this solution meets your needs, we can proceed with implementing it. However, if you have other datasets or future needs that require more flexibility, you need to work within the single, unique identifier model.
Please let me know how you’d like to move forward, and I’m happy to assist in any way.
