355
Trying to add IgcDockmanager to angular 17 project - getting Ivy error
I am following the instructions under Usage on this page
https://ko.infragistics.com/products/ignite-ui-angular/angular/components/dock-manager
And I am getting the following error when my app builds
node_modules/@infragistics/igniteui-dockmanager/dist/types/components/dockmanager/dockmanager.public-interfaces.d.ts:460:22
460 export declare class IgcDockManagerComponent extends HTMLElement {
This likely means that the library (@infragistics/igniteui-dockmanager) which declares IgcDockManagerComponent is not compatible with Angular Ivy. Check if a newer version of the library is available, and update if so. Also consider checking with the library's authors to see if the library is expected to be compatible with Ivy.
Here are the angular versions in my package.json dependencies section
  "dependencies": {
    "@angular/animations": "~17.2.2",
    "@angular/cdk": "^17.3.3",
    "@angular/common": "~17.2.2",
    "@angular/compiler": "~17.2.2",
    "@angular/core": "~17.2.2",
    "@angular/forms": "~17.2.2",
    "@angular/platform-browser": "~17.2.2",
    "@angular/platform-browser-dynamic": "~17.2.2",
    "@angular/router": "~17.2.2",
    "@infragistics/igniteui-angular": "~17.2.2",
    "@infragistics/igniteui-dockmanager": "^1.14.3"
I have another angular application where the Dockmanager bulds and works fine, and here are my versions:
  "dependencies": {
    "@angular/animations": "~17.3.9",
    "@angular/common": "~17.3.9",
    "@angular/compiler": "~17.3.9",
    "@angular/core": "~17.3.9",
    "@angular/forms": "~17.3.9",
    "@angular/platform-browser": "~17.3.9",
    "@angular/platform-browser-dynamic": "~17.3.9",
    "@angular/router": "~17.3.9",
Thinking that the angular version was the issue, I upgraded my app from 17.2.2 to 17.3.9, but I still get the error.
How do I resolve this issue?
