30
How can i fix this issue when applying style
@import '../../../../../assets/sass/theme'
.dialog-content
display: flex
justify-content: center
align-items: center
width: 45vw
height: 65vh
.variant-options
display: flex
gap: 1rem
.variant-card
text-align: center
padding: 1rem
width: 100%
height: 100%
position: relative
background-color: transparent
.variant-image
border-radius: 15px
object-fit: scale-down
.variant-text
font-size: 6rem
line-height: normal
font-weight: bold
position: absolute
top: 32%
color: #3A3A3A
$dialogTheme: dialog-theme(
$background: #011627,
$title-color: #ecaa53,
$message-color: #fefefe,
$border-radius: 0.3
.overlay1
::ng-deep
   @include dialog($dialogTheme)
  • 500
    To effectively apply custom styles to the igx-dialog component in your Angular application, it's essential to configure both the SCSS and TypeScript files appropriately. Here's a comprehensive guide:
    1. Importing the Theming Module
    Ensure you've imported the Ignite UI for Angular theming module correctly. For versions prior to 13, use:
    @import '~igniteui-angular/lib/core/styles/themes/index';
    For version 13 and above, use:
    @use 'igniteui-angular/theming' as *;
    1. Defining a Custom Dialog Theme
    Create a custom theme by extending the dialog-theme and setting your desired parameters:
    $my-dialog-theme: dialog-theme(
      $title-color: #ECAA53,
      $message-color: #FEFEFE,
      $border-radius: 0.3
    1. Applying the Theme
    To apply the custom theme, include it in your styles. If your component uses Emulated ViewEncapsulation, penetrate this encapsulation using ::ng-deep:
    :host {
      ::ng-deep {
        @include dialog($my-dialog-theme);
    If $legacy-support is set to false (default), include the component CSS variables like this:
    :host {
      @include css-vars($my-dialog-theme);
    1. Providing an Overlay Outlet
    Since the dialog uses the IgxOverlayService, ensure your custom theme reaches the dialog window by providing a specific outlet in your template:
    <div igxOverlayOutlet>
      <igx-dialog #dialog1>
      </igx-dialog>
    </div>
    1. Import Necessary Modules
    Begin by importing the required classes from Angular's core and Ignite UI for Angular:
    import { Component, ViewChild, OnInit } from '@angular/core';
    import { IgxOverlayOutletDirective, IgxDialogComponent, CloseScrollStrategy, GlobalPositionStrategy } from 'igniteui-angular';
    1. Define ViewChild Decorators
    In your component class, use the @ViewChild decorator to reference the overlay outlet directive and the dialog component:
    export class YourComponent implements OnInit {
      @ViewChild(IgxOverlayOutletDirective, { static: true })
      public outlet: IgxOverlayOutletDirective;
      @ViewChild('dialog1', { read: IgxDialogComponent, static: true })
      public dialog: IgxDialogComponent;
      private _dialogOverlaySettings;
    Here:
    • outlet captures the IgxOverlayOutletDirective from your template.
    • dialog references the IgxDialogComponent identified by the template reference variable #dialog1.
    1. Initialize Overlay Settings
    Within the ngOnInit lifecycle hook, define the overlay settings for your dialog:
    public ngOnInit() {
      this._dialogOverlaySettings = {
        modal: true,
        outlet: this.outlet,
        scrollStrategy: new CloseScrollStrategy(),
        positionStrategy: new GlobalPositionStrategy()
    This configuration ensures that the dialog behaves as a modal, utilizes the specified outlet, and applies the desired scroll and position strategies.
    1. Create a Method to Open the Dialog
    Implement a method to open the dialog with the defined settings:
    public openDialog() {
      this._dialogOverlaySettings.outlet = this.outlet;
      this.dialog.open(this._dialogOverlaySettings);
    This method assigns the outlet to the overlay settings and opens the dialog accordingly.
    Reference Sample for Implementation
    For a complete example of how this is implemented, check out this working sample on StackBlitz.
    The described scenario could be observed here:
    By following these steps, you can effectively control the igx-dialog component programmatically and apply custom styles as needed.
    For more detailed information, refer to the official documentation:
    These resources provide comprehensive guidance on managing and styling the igx-dialog component in Angular applications.
    Associate Software Developer
