this is my html:
<div class="pivot-container" [hidden]="!(boqGridRows && boqGridRows.length > 0)"> <igx-pivot-grid #boqPivotGrid [data]="boqGridRows" [pivotConfiguration]="pivotConfig" height="100%" width="100%" [superCompactMode]="true" [defaultExpandState]='true' ></igx-pivot-grid> <igx-pivot-data-selector #dataSelector [grid]="boqPivotGrid"></igx-pivot-data-selector> </div>
private configurePivotGrid() { const formatter = (value) => { return isNaN(value) || value === null || value === undefined ? '' : new Intl.NumberFormat('en-US', { minimumFractionDigits: 2, maximumFractionDigits: 2, }).format(value); }; const areaTypeDimensions = this.areaTypeList.map(areaType => ({ memberName: areaType.name, displayName: areaType.name, memberFunction: (record) => { const areaTypeValue = record.areaTypeValues.find(value => value.areaType === areaType.name); return areaTypeValue ? `${areaTypeValue.areaValue}` : ''; }, enabled: false })); this.pivotConfig = { pivotKeys: { aggregations: 'aggregations', records: 'records', children: 'children', level: 'level', columnDimensionSeparator: '*', rowDimensionSeparator: '*', }, columns: [ ], rows: [ { memberName: 'discipline', displayName: 'Discipline', enabled: true}, { memberName: 'schedule', displayName: 'Schedule', enabled: false} ], values: [ { member: 'ccr', displayName: 'CCR', aggregate: { aggregator: IgxPivotNumericAggregate.sum, key: 'SUM', label: 'SUM' }, enabled: false, formatter: (value) => formatter(value) }, { member: 'factoredManhours', displayName: 'Factored Manhours', aggregate: { aggregator: IgxPivotNumericAggregate.sum, key: 'SUM', label: 'SUM' }, enabled: false, formatter: (value) => formatter(value) }, { member: 'labourCost', displayName: 'Labour Cost', aggregate: { aggregator: IgxPivotNumericAggregate.sum, key: 'SUM', label: 'SUM' }, enabled: false, formatter: (value) => formatter(value) }, { member: 'manhours', displayName: 'Manhours', aggregate: { aggregator: IgxPivotNumericAggregate.sum, key: 'SUM', label: 'SUM' }, enabled: true, formatter: (value) => formatter(value) }, { member: 'materialCost', displayName: 'Material Cost', aggregate: { aggregator: IgxPivotNumericAggregate.sum, key: 'SUM', label: 'SUM' }, enabled: false, formatter: (value) => formatter(value) }, { member: 'quantity', displayName: 'Quantity', aggregate: { aggregator: IgxPivotNumericAggregate.sum, key: 'SUM', label: 'SUM' }, enabled: true, formatter: (value) => formatter(value) }, { member: 'totalCost', displayName: 'Total Cost', aggregate: { aggregator: IgxPivotNumericAggregate.sum, key: 'SUM', label: 'SUM' }, enabled: true, formatter: (value) => formatter(value) } ], filters: [ ...areaTypeDimensions, { memberName: 'drawingNumber', displayName: 'Drawing Number', enabled: false }, { memberName: 'drawingSheet', displayName: 'Drawing Sheet', enabled: false}, { memberName: 'drawingRevision', displayName: 'Drawing Revision', enabled: false}, { memberName: 'material', displayName: 'Material', enabled: false}, { memberName: 'r6Item', displayName: 'R6 Item', enabled: false}, { memberName: 'r7Item', displayName: 'R7 Item', enabled: false}, { memberName: 'unitSymbol', displayName: 'Unit Symbol', enabled: false } ].sort((a, b) => a.displayName.localeCompare(b.displayName)) }; }
public onItemSort( _: Event, dimension: IPivotDimension, dimensionType: PivotDimensionType ) { const dimensions = this.dataSelector.dims; dimensions.sort((a, b) => a.displayName.localeCompare(b.displayName)); console.log(dimensions); this.dataSelector.grid.dimensionsChange.emit({ dimensions: dimensions, dimensionCollectionType: dimensionType, }); console.log(this.dataSelector.grid.allDimensions); const test = this.dataSelector.grid.allDimensions.sort((a, b) => a.displayName.localeCompare(b.displayName)); console.log(test); this.dataSelector.grid.dimensionsChange.emit({ dimensions: test, dimensionCollectionType: dimensionType, }); this.cdr.detectChanges(); }
and then call it within the oninit. The issue I'm having is that in the console logs I am seeing that the data is sorted, but it does not reflect that on the grid itself and still shows them in the order of columns, rows. filters and then values. What I'm wanting is to sort the list regardless of which dimension it is apart of.Is there also a way to sort the data within the individual members like:
For example the data within disciplines will be things such as:020- Discipline 1
010 - Discipline 2
I would like order them based off of the numbers at the start, is something like that possible?
Just to expand on this a bit more, I can there are the sort icons on the grid itself, but it's whether can sort the data within the filter list?
Ah okay I see, thank you
Hello Lewis,
I have been looking into your questions and what I can say regarding the rows, columns, filters, and values dimensions order is that the way the members are displayed is as follows:
<igx-list> <igx-list-item *ngFor="let item of dims"> … </igx-list-item> <igx-list-item *ngFor="let item of values"> … </igx-list-item> </igx-list>
where the dims variable is determined by the allDimentions property of the pivot grid and the values by the pivotConfiguration.values property. Internally, the allDimentions property implementation is as follows:
public get allDimensions() { const config = this._pivotConfiguration; if (!config) return []; return (config.rows || []).concat((config.columns || [])).concat(config.filters || []).filter(x => x !== null && x !== undefined); }
As can be observed by the above code snippets, the order of the items is predefined and currently, there are no exposed options that allow modifying it.
What I can suggest, in order to have this feature implemented in any of our future releases, is logging this as a feature request in our GitHub repository here. Remember when submitting your idea to explain the context in which a feature would be used and why it is needed.
Additionally, regarding sorting the items in the filter dialog, after an investigation, I noticed that this behavior is already logged as a feature request in our GitHub repository here. I would suggest addressing any concerns and/or questions there as this will give you the opportunity to directly communicate with our development team regarding this matter and get notifications whenever new information is available.
In order to receive a notification whenever new information is available, please make sure that you are subscribed to the issues. This can be achieved via the “Subscribe” button.
Please let me know if you need any further information on the matter.
Sincerely, Riva Ivanova Software Developer
