20
iggrid fixed header not aligned with row data
I am setting height of iggrid to set fixed header with vertical scrolling, it is fixed the header, but its not aligned with row data, please refer to this snap.
Below is the code:
$("#tblCheckInQueList").igGrid({
primaryKey: "templateID",
width: '100%',
height: '170px',
autofitLastColumn: false,
autoGenerateColumns: false,
renderCheckboxes: true,
dataSource: data,
showHeader: true,
multiSelection: {
enabled: true
columns: [
{ headerText: "AppTypeMapID", headerCssClass: "", key: "appTypeMapID", dataType: "number", columnCssClass: "", hidden: true },
{ headerText: "TemplateID", headerCssClass: "", key: "templateID", dataType: "number", columnCssClass: "", hidden: true },
{ headerText: "Select", headerCssClass: "", key: "select", dataType: "bool", columnCssClass: "", hidden: true },
{ headerText: "Questionnaire(s)", headerCssClass: "", key: "questTemplate", dataType: "string", columnCssClass: "smd-font-color" },
{ headerText: "Portal", key: "portal", dataType: "boolean", hidden: true },
headerText: "Portal", key: "portal1", dataType: "boolean", unbound: true, columnCssClass: "text-left",
formula: function displayStatus(data, grid) {
var ActiveStatus = null;
if (data["portal"] == true) {
ActiveStatus = "<label class='custom-control custom-checkbox pmd-checkbox smd-margin-bottom-none'><input type='checkbox' name='CheckInQuest_" + data["templateID"] + "' class='custom-control-input' onclick='activeChange(this)' id='chkPortalQI_" + data["templateID"] + "' checked='checked' /><span class='custom-control-label pmd-checkbox-ripple-effect'></span></label>";
else {
ActiveStatus = "<label class='custom-control custom-checkbox pmd-checkbox smd-margin-bottom-none'><input type='checkbox' name='CheckInQuest_" + data["templateID"] + "' class='custom-control-input' onclick='activeChange(this)' id='chkPortalQI_" + data["templateID"] + "' /><span class='custom-control-label pmd-checkbox-ripple-effect'></span></label>";
return ActiveStatus;
{ headerText: "Clipboard", key: "clipboard", dataType: "boolean", hidden: true },
headerText: "Clipboard", key: "clipboard1", dataType: "boolean", unbound: true, columnCssClass: "text-left",
if (data["clipboard"] == true) {
ActiveStatus = "<label class='custom-control custom-checkbox pmd-checkbox smd-margin-bottom-none'><input type='checkbox' name='CheckInQuest_" + data["templateID"] + "' class='custom-control-input' onclick='activeChange(this)' id='chkClipboardQI_" + data["templateID"] + "' checked='checked' /><span class='custom-control-label pmd-checkbox-ripple-effect'></span></label>";
else {
ActiveStatus = "<label class='custom-control custom-checkbox pmd-checkbox smd-margin-bottom-none'><input type='checkbox' name='CheckInQuest_" + data["templateID"] + "' class='custom-control-input' onclick='activeChange(this)' id='chkClipboardQI_" + data["templateID"] + "' /><span class='custom-control-label pmd-checkbox-ripple-effect'></span></label>";
{ headerText: "Both", key: "both", dataType: "boolean", hidden: true },
headerText: "Both", key: "both1", dataType: "boolean", unbound: true, columnCssClass: "text-left",
if (data["both"] == true) {
ActiveStatus = "<label class='custom-control custom-checkbox pmd-checkbox smd-margin-bottom-none'><input type='checkbox' name='CheckInQuest_" + data["templateID"] + "' class='custom-control-input' onclick='activeChange(this)' id='chkBothQI_" + data["templateID"] + "' checked='checked' /><span class='custom-control-label pmd-checkbox-ripple-effect'></span></label>";
else {
ActiveStatus = "<label class='custom-control custom-checkbox pmd-checkbox smd-margin-bottom-none'><input type='checkbox' name='CheckInQuest_" + data["templateID"] + "' class='custom-control-input' onclick='activeChange(this)' id='chkBothQI_" + data["templateID"] + "' /><span class='custom-control-label pmd-checkbox-ripple-effect'></span></label>";
// Grid Settings
features: [
enableCheckBoxes: true,
enableRowNumbering: false,
checkBoxStateChanging: function (evt, ui) {
isFiredFromCheckboxCIQ = true;
var grid = $("#tblCheckInQueList").data("igGrid");
if (ui.newState.toLowerCase() == 'off') {
grid.dataSource.updateRow(parseInt(ui.rowKey), { portal: false, clipboard: false, both: false }, true);
$(ui.row[0]).find("input[id^='chkPortalQI']").prop('checked', false);
$(ui.row[0]).find("input[id^='chkClipboardQI']").prop('checked', false);
$(ui.row[0]).find("input[id^='chkBothQI']").prop('checked', false);
else {
grid.dataSource.updateRow(parseInt(ui.rowKey), { both: true }, true);
$(ui.row[0]).find("input[id^='chkBothQI']").prop('checked', true);
mode: 'row',
persist: true,
multipleSelection: true,
activation: true,
rowSelectionChanging: function (evt, ui) {
schApptTypeIsChangesOnKeyup = true;
if (isFiredFromCheckboxCIQ) {
isFiredFromCheckboxCIQ = false;
else {
return false;
enableVerticalRendering: false,
type: "local",
columnSettings: [
columnKey: "questTemplate",
allowSorting: false,
columnKey: "portal1",
columnKey: "clipboard1",
columnKey: "both1",
Please help to fix this issue.
    It is quite difficult if you do not understand about setting columns and rows. Each value really needs to be exact. Easy reference through scratch games shares you update.
    Let our expert content writers craft blogs, articles, product descriptions, ebooks, and more for you.
  • 3995
    It could be bootstrap or some custom styles related to the sample
    I tried it in the following fiddle. Please check it out. The headers are aligned as expected. Can you modify it and send it back with the misaligned headers?
