Can we make the column read only while updating and allow to enter value on add new row.
Indra
Hello, Sure, please take your time to test the suggested solution. Thank you for your cooperation. Regards, Georgi Anastasov Entry Level Software Developer Infragistics
Thank you. Will work and let you know if any issue.
Hello Indra,
Thank you for the code snippet provided.
I have been looking into your question and this is the expected behavior of the grid as the PrimaryKey of the grid must be unique for each row and not repeated for two or more rows as this causes conflicts such as not being able to edit the given new row as there is another initially with the same primary key.
However, the click function of the button you prepared is correct with the only difference that you set the same primary key to the newly added row. What you need to do is find another primary key for example the next in the line, but necessarily unique.
What I could suggest as an approach is in iterating through the selected rows in the given function and creating a variable that will take the next number in the row of primary keys, and this will be done by taking the length of the data source and adding one:
let pk = $("#grid1").data('igGrid').dataSource._data.length + 1;
This primary key must be of the same datatype as the column itself, in this case it is of type string, so you will convert it to a string:
let temp = pk.toString();
After that, when initializing the new row on the primary key of the line, you will set this new unique number:
var rowObj = { "CustomerID": temp, "CompanyName": $("#grid1").igGrid("getCellValue", rowId, "CompanyName"), "ContactName": $("#grid1").igGrid("getCellValue", rowId, "ContactName"), "Address": $("#grid1").igGrid("getCellValue", rowId, "Address"), "City": $("#grid1").igGrid("getCellValue", rowId, "City"), "Salary": $("#grid1").igGrid("getCellValue", rowId, "Salary"), };
The described scenario could be observed here:
In addition, I have prepared small sample illustrating this behavior which could be found attached here. Please test it on your side and let me know how it behaves.
0488.igGridCopyButton.zip
I have enhanced this functionality by adding the copy row button. Select the row and copy. But it is not work
@{ ViewData["Title"] = "Home Page"; } @using Infragistics.Web.Mvc @model igGridReadOnly.Models.CustomersViewModel <div> @(Html.Infragistics().Grid(Model.Customers.AsQueryable()). ID("grid1"). AutoGenerateColumns(false). AutoGenerateLayouts(true). Height("500px"). Width("1000px"). PrimaryKey("CustomerID"). AutoCommit(true). Caption("Customers"). RenderCheckboxes(true). Columns(column => { column.For(x => x.CustomerID).HeaderText("Customer ID").DataType("string").Hidden(false); column.For(x => x.CompanyName).HeaderText("Company Name").DataType("string").Hidden(false); column.For(x => x.ContactName).HeaderText("Contact Name").DataType("string").Hidden(false); column.For(x => x.Address).HeaderText("Address").DataType("string").Hidden(false); column.For(x => x.City).HeaderText("City").DataType("string").Hidden(false); column.For(x => x.Salary).HeaderText("Salary").DataType("number").Hidden(false); }) .Features(features => { features.Updating(). //enable row add EnableAddRow(true). //client event for start editing row AddClientEvent(GridUpdatingClientEvents.EditRowStarting, "editRowStarting"). AddClientEvent(GridUpdatingClientEvents.EditRowEnded, "editRowEnded"). EditMode(GridEditMode.Row). ColumnSettings(settings => { //set the column you want to be readonly first to false settings.ColumnSetting().ColumnKey("CustomerID").ReadOnly(false); settings.ColumnSetting().ColumnKey("CompanyName").ReadOnly(false); }); features.Selection().Mode(SelectionMode.Row).MultipleSelection(true).AllowMultipleRangeSelection(true); }). DataBind(). Render()) </div> <input type="button" id="copyRow" class="button-style" value="Copy Row" /> <script> //handle the event function editRowStarting(evt, ui) { //grid var grid = $("#grid1"); //column setting var colSettings = $("#grid1").igGridUpdating("option", "columnSettings"); //when adding row columns will be readonly = false //when editing row columns will be readonly = true if (ui.rowAdding === false) { //set the columns read only property to true when edit row colSettings[0].readOnly = true; colSettings[1].readOnly = true; //apply the settings grid.igGridUpdating("option", "columnSettings", colSettings); } } //on row ended function editRowEnded(evt, ui) { var grid = $("#grid1"); var colSettings = $("#grid1").igGridUpdating("option", "columnSettings"); //set columns read only to property false for next editing or adding colSettings[0].readOnly = false; colSettings[1].readOnly = false; grid.igGridUpdating("option", "columnSettings", colSettings); } $("#copyRow").igButton({ labelText: $("#copyRow").val(), click: function (e) { var rows = $('#grid1').igGridSelection('selectedRows'); $.each(rows, function (ix, el) { rowId = el.element.attr("data-id"); var rowObj = { "CustomerID": $("#grid1").igGrid("getCellValue", rowId, "CustomerID"), "CompanyName": $("#grid1").igGrid("getCellValue", rowId, "CompanyName"), "ContactName": $("#grid1").igGrid("getCellValue", rowId, "ContactName"), "Address": $("#grid1").igGrid("getCellValue", rowId, "Address"), "City": $("#grid1").igGrid("getCellValue", rowId, "City"), }; $("#grid1").igGridUpdating("addRow", rowObj); }); } }); </script>
Please suggest
Hello Indra, Sure, please take your time to test the suggested solution. Thank you for your cooperation. Regards, Georgi Anastasov Entry Level Software Developer Infragistics
