190
Summary Operands Asp.Net MVC Helper (.net core)
Hi There,
I'm using the Summary feature of the grid, but i just want to display the Sum operand, not all of the values.
How can i go about doing this? IT's a basic sum operation on the grid fields. Can i override the summary displays to include just the Sum total?
Here's the code snipped in cshtml
features.Summaries().Type(OpType.Local).ColumnSettings(settings =>
settings.ColumnSetting().ColumnIndex(0).AllowSummaries(false);
    This method for customizing grid summaries in ASP.NET MVC is great for scenarios where clean output is required, especially in dashboards or billing systems. I've also worked on similar features while building tools to help users check their utility data. You can check it online here, it might give you some practical ideas for displaying summary values efficiently.
    .ColumnKey("Amount")
    .SummaryOperands(operands =>
    operands.OperandName("Sum").Active(true);
    This ensures that only the Sum total is shown in the grid footer, without other operands like Count, Min, or Max. You can also control this via the DisplayFormat property if supported in your grid configuration
    Em projetos que envolvem cálculo de horas, a calculadora de horas pode ser facilmente integrada para somar períodos automaticamente. Article writing
    Thumbnails are not just graphics—they are psychological tools designed to influence decisions. Every color, face, and shape has an impact on how viewers perceive your video. That’s why using tools like YT Thumbnail Saver to study viral designs can give you a massive advantage. You’ll understand the psychology behind successful thumbnails and apply it to your own channel.
    Offline posted in reply to Mark Customer
    To show only the Sum operand for Fesco bill online grid, simply adjust the summary settings as shown. This configuration will display the total sum only, without individual values in each row.
    Interesting discussion on using ASP.NET MVC with Ignite UI! For those balancing technical coursework and assignments, the coursework help service can provide expert assistance in ensuring your work is top-notch and well-structured.
