I am working on migration project. I need to update from Version 2015 to Version 20.1. The utility tool its not able to update the solution,
Problem 1.
Using Version utility tool the log file.
07:41:42: Running VS2012/VS2013 Add-in UI Version 20.1.20201.1 07:41:42: Gathering volume and assembly information. 07:41:42: Could not locate registry entry Software\Microsoft\.NETCore\v4.5\AssemblyFoldersEx where we look for installed products. 07:41:44: Analyzing UCA.Web.Portal.csproj... 07:41:44: The project has references that need to be updated. 07:41:48: Updating UCA.Web.Portal.csproj... 07:41:48: C:\NaturalDisasterZip-3\Code_Merge\UCA.Web.Portal\UCA.Web.Portal.csproj has been backed up. 07:41:48: No matching assembly located in available assemblies Infragistics.Web.Mvc 07:41:49: at Infragistics.VersionUtilitySupport.Core.Product.AssemblyXmlFile.ThrowExceptionWhenAssemblyCouldNotBeFound(String assemblyName, Boolean checkAdditionalMessage) at Infragistics.VersionUtilitySupport.Core.Product.AssemblyXmlFile.LocateNewAssembliesNodeforCurrentAssembly(String assemblyName) at Infragistics.VersionUtilitySupport.Core.File.Types.ProjectFile.Upgrade(String rootDirectory)
Problem 2.
I am using visual studio 2015 professional. In our application we are using the three dlls
1.Infragistics.Web.Mvc
2. Infragistics.Web.Mvc.Documents.Core
3. Infragistics.Web.Mvc.Documents.Excel
After installing the new version I found the "Infragistics.Web.Mvc" dll and I have updated the same and I am able to run the application,
I am facing an issue on groupby grids . The razor code is
@(Html.Infragistics().Grid(Model.objQueueFilterlobList.AsQueryable()) .ID("grdQueueFilterLOB") .Height("400px") .Width("1200px") .PrimaryKey("WHQueueGroupId") .AutoGenerateColumns(false) .AutoGenerateLayouts(false) .AutoCommit(true) .RenderCheckboxes(false) .FixedHeaders(true) .Columns(column => { column.For(x => x.WHQueueGroupId).HeaderText("ID").Hidden(true); column.For(x => x.ShortName).HeaderText("Queue Group").Width("250px"); column.For(x => x.OrderCount).HeaderText("Order Count").Width("250px").Template("<a href='#' onclick = 'QueueFilterLOBRowSelectOrderCount(${WHQueueGroupId},\"${SiteID}\",\"${ShortName}\")'>${OrderCount}</a>"); column.For(x => x.HighPriorityCount).HeaderText("Priority").Width("250px").Template("{{if ${HighPriorityCount} > 0}}<label style=\"color:green; height:8px;\" >${HighPriorityCount}</label>{{else}} <label style=\" height:8px;\" >${HighPriorityCount} </label> {{/if}}"); column.For(x => x.DisplayString).HeaderText("Time In Queue").Width("250px"); column.For(x => x.SiteID).HeaderText("LOB").Hidden(true); }).AlternateRowStyles(true) .Features(features => { features.Paging().PageSize(20); features.Selection().Mode(SelectionMode.Row).MultipleSelection(false); features.GroupBy().Persist(true).ColumnSettings(groupedGolumn => { groupedGolumn.ColumnSetting().ColumnKey("SiteID").IsGroupBy(true); }).GroupByAreaVisibility(GroupAreaVisibility.Hidden).GroupedRowTextTemplate("<label style=\"text-align: left; height:8px;\" ><b>${key}: ${val} (${count} Items)</b></label>");
}) .DataBind() .Render())
Getting this error
and the grid doesnt load.
Problem 3
Regarding the missing dlls. 2. Infragistics.Web.Mvc.Documents.Core & 3. Infragistics.Web.Mvc.Documents.Excel
cannot be found I found Infragistics.Web.Documents.Core & Infragistics.Web.Documents.Excel dll how to get them or let me know the code update so that my export to excel functionality is working as expected.
Problem 4.
The hyper links or not visible on the new grid
Highligted one are links but its looks line a normall text.
Please Suggest.
Thanks in advance.
Yes, this version is really fun and easy to play on level devil - not a troll game!
The game can be Geometry Dash played for short periods of time or for long periods of time because it is easy to pick up and play but also has a lot of depth and challenge.
When it comes to working with Level Devil Game, I have the same question as you have. It is now fine with everything.
Some researchers to analyze the data show positive values slope 3 free online
Really?
It's a good version! spin wheel free
