70
DatepickerOptions in MVC View
I am trying to add the code to make a datepicker into just a month and/or year picker in a MVC View, not via javascript. I have code that looks like this:
@(Html.Infragistics().DatePicker()
.ID(EndMonthId)
.Width("100px")
.Height(24)
.Value(month != null ? month : DateTime.Now.Month)
.DateDisplayFormat("MMMM")
.DateInputFormat("MMMM")
.HtmlAttributes(new System.Collections.Generic.Dictionary<string, object>() { { "class", "financialDashboardDatePicker" } })
.TextAlignment(TextEditorTextAlignment.Left)
.DataMode(DateEditorDataMode.DisplayModeText)
.MinValue(new DateTime(1753, 1, 1))
.ValidatorOptions(options =>
options.Required(true, "*");
options.Date(true, "*");
options.OnBlur(false);
options.OnChange(false);
options.OnSubmit(false);
.Render()
I have tried .Datepickeroptions(x) but can find nowhere how I define x for month/date only. I have tried adding code you supplied elsewhere for this issue:
features.Updating().ColumnSettings(cs =>
cs.ColumnSetting().ColumnKey("StartDate").EditorType(ColumnEditorType.DatePicker).Required(true).EditorOptions("datepickerOptions: {changeYear: true, changeMonth: true}");
However, it won't accept featires, .Features. or any other variation on that like it would in an iggrid. Please help me on the proper syntax.
- John Cannon
    .ID("EndMonthId")
    .DatePickerOptions(options =>
    options.ChangeMonth(true);
    options.ChangeYear(true);
    options.AddClientEvent("onChangeMonthYear", "onChangeMonthYear");
    Additionally, the color of the dropdown items should be set to black:
    Replaced these codes and working fine for me
    thanks
  • 1320
    Verified Answer
    Hello John,
    After investigating this further, I determined that year and month selection could be enabled by setting the datePicker options “changeYear” and “changeMonth” as follows:
                        .ID("EndMonthId")
    <style>
            .ui-datepicker-month {
                color: black;
            .ui-datepicker-year {
                color: black;
    </style>
    However, new date is not selected only by changing the month or the year, this is why I have bound a method to the onChangeMonthYear event, where new Date is selected programmatically:
    function onChangeMonthYear(year, month) {
                $("#EndMonthId").igDatePicker("selectDate", new Date(year, month, 1));
    Additionally, if the calendar should not be displayed, what I could suggest is setting the display to none:
    .ui-datepicker table {
                display: none;
    Below I am attaching a sample, demonstrating the described behavior. Please test it on your side and let me know if you need any further information regarding this matter.
    Monika Kirkova,
    4643.Home.zip
