1470
igUpload: e.AdditionalDataFields is always NULL
Ran across this issue: https://github.com/IgniteUI/ignite-ui/issues/2134#issue-938844956 and wondering if this issue affects the MVC helper as well?
With the file upload, I need to capture user input that is associated with the file.  I have looked at https://www.igniteui.com/help/igupload-using-server-side-events,  I have had no luck with passing the data, even the static text from the example does not come acorss.
I have the following in Application_Start()
Dim controlId As String = "igUploadProjectDocTypes"
        UploadProgressManager.Instance.AddStartingUploadEventHandler(controlId, AddressOf Controllers.ProjectDocumentsController.igUpload_UploadStarting)
        UploadProgressManager.Instance.AddFinishedUploadEventHandler(controlId, AddressOf Controllers.ProjectDocumentsController.igUpload_UploadFinished)
And both events are being called (breakpoints are hit)
Public Shared Sub igUpload_UploadStarting(sender As Object, e As UploadStartingEventArgs)
Public Shared Sub igUpload_UploadFinished(sender As Object, e As UploadFinishedEventArgs)
@(Html.Infragistics.Upload() _
                   .ID("igUploadProject") _
                   .Mode(UploadMode.Multiple) _
                   .MultipleFiles(True) _
                   .AutoStartUpload(False) _
                   .ProgressUrl(Url.Content("~/IGUploadStatusHandler.ashx")) _
                   .ControlId("igUploadProjectDocTypes") _
                   .Render()
The alert for with `JQuery` does execute.
<script type="text/javascript">
    $(function () {
        alert('jQuery');
        $("#igUploadProject").on("iguploadonformdatasubmit"function (evt, ui) {
            alert('on(iguploadonformdatasubmit)');
            $("#igUploadProject").igUpload("addDataField", ui.formData, { "name""Parameter Name""value""Value" });
        $("#igUploadProject").on("iguploadfileuploading"function (evt, ui) {
            alert('on(iguploadfileuploading)');
            alert(ui.fileInfo.serverMessage);
        $("#igUploadProject").on("iguploadfileuploaded"function (evt, ui) {
            alert('on(iguploadfileuploaded) ' + ui.fileInfo.serverMessage);
        $("#igUploadProject").on("iguploadonerror"function (evt, ui) {
            // This property can be set during the
            // server event UploadStarting. If not set it’s
            // an empty string. (You can use it to display custom error messages.)
            alert(ui.serverMessage);
    </script>
Versions:
Infragistics.Web.Mvc: 5.21.1.7
IgniteUI: 21.1.11
JQuery: 3.6.0
Update 2021-07-21
I switch to the jQuery version and the upload works:
    $(function () {
        $("#upload").igUpload({
            mode: "single",
            autostartupload: false,
            controlId: "upload",
            useSingleRequest: true,
            progressUrl: "../../IGUploadStatusHandler.ashx"
        $("#upload").on("iguploadfileuploading", function (evt, ui) {
            alert('on("iguploadfileuploading"');
        $("#upload").on("iguploadfileuploaded", function (evt, ui) {
            alert('on("iguploadfileuploaded"' + ui.fileInfo.serverMessage);
        $("#upload").on("iguploadonerror", function (evt, ui) {
        //$("#upload").on("iguploadonformdatasubmit", function (evt, ui) {
        //    $("#upload").igUpload("addDataField", ui.formData, { "name": "Parameter Name", "value": "Value" });
        // Workaround:
            // switct form data parameters order
            var fileId = "upload_" + ui.fileId + "__frm_if";
            var fileInfo = ui.formData.get(fileId);
            ui.formData.delete("upload_0__frm_if");
            ui.formData.append("Parameter Name", "Value");
            ui.formData.append(fileId, fileInfo);
        alert('jQuery');
</script>
<div id="upload"></div>
  • 1320
    Hello Pete,
    I am glad that you were able to achieve your requirement. Additionally, the described approach could be used with igUpload defined in Razor syntax:
    @(Html.Infragistics().Upload()
                    .ID("igUpload1")
                    .AutoStartUpload(true)
                    .ControlId("upload1")
                    .ProgressUrl("~/IGUploadStatusHandler.ashx")
                    .Render())
            $(function () {
                $("#igUpload1").on("iguploadonformdatasubmit", function (evt, ui) {
                    var fileInfo = ui.fileId;
                    var fileName = ui.fileInfo.path;
                    ui.formData.append("fileName", fileName);
        </script>
    Below I am attaching a sample with igUpload defined in Razor syntax. Please test it on your side and let me know if you need any further information regarding this matter.
    Monika Kirkova,
    5344.igUploadMVC.zip
