https://ko.infragistics.com/products/ignite-ui-blazor/blazor/components/doughnut-chart.html
I was trying to use DoughnutChart to make Dashboard's component.
But in this example. There's a example of what modules should be called, and how to set dataSource.
But it is on typeScript source and does not offer how the dataSource binded.
So here's a question.
1. How can i use DoughnutChart like blazor component?2. How can i bind DoughnutChart with dataSource? and what the structure of dataSource look like?
and..I replied last post's reply but it seems there's no reply. Could you tell me how is it going?
Hello Yeowon,
At the time of writing this, the Infragistics’ Ignite UI for Blazor documentation is under some maintenance as we are currently working on getting a code-viewer to be added to our samples so that you can see all of the code required for each sample on each documentation topic.
With the above said, you can find multiple samples for the DoughnutChart in this GitHub repository.
