Blazor Server App- Chart not rendering
I have created a Blazor Server App and implemented a chart exactly as documented in your sample area:
Pages/_Host.cshtml
<script src="_content/IgniteUI.Blazor/app.bundle.js"></script>
<script src="_framework/blazor.server.js"></script>
Startup.cs file:
using IgniteUI.Blazor.Controls; // ... public void ConfigureServices(IServiceCollection services) { // ... services.AddScoped(typeof(IIgniteUIBlazor), typeof(IgniteUIBlazor)); }
https://ko.infragistics.com/products/ignite-ui-blazor/blazor/components/charts/types/column-chart
Everything compiles, I have another page that uses the Grid just fine, yet all that renders for the chart is the following:
I am running VS Professional 2019 version 16.11.8, .Net 5.0 framework, IgniteUI.Blazor 21.2.1
Any pointers greatly appreciated at this point...
Parents
No Data
Reply
  • 34810
    Hello Dan,
    It appears from your screenshot that the only thing that is showing up is the IgbLegend component and the title <span> element for that legend. The fact that the legend has entries means that the chart is there and it is acknowledging that there are two series in the chart – or at least that there are two that have the legend assigned to it.
    I am curious to know if you are currently using a percentage Height / Width for the chart in this case? If you are, then as a test, can you please try giving a pixel Height / Width for the chart (e.g. Height=”500px”) to see if it renders? If it does, this means you are missing some CSS to allow support of the percentage heights/widths of the elements in your application, as the parent elements need to have a size assigned to them in order for percentage Height / Width to work.
Children
No Data
