All grids for MVC 19.1 throws exception in this row for HttpPost. HttpGet works correct. It also worked in MVC 17.2. How I can fix or debug JSON content for grids/datasets?
@(Html.Infragistics().Grid(Model))
JsonReaderException: Unexpected character encountered while parsing value: _. Path '', line 0, position 0.] Newtonsoft.Json.JsonTextReader.ParseValue() +1111 Newtonsoft.Json.JsonTextReader.Read() +26 Newtonsoft.Json.Serialization.JsonSerializerInternalReader.ReadForType(JsonReader reader, JsonContract contract, Boolean hasConverter) +94 Newtonsoft.Json.Serialization.JsonSerializerInternalReader.Deserialize(JsonReader reader, Type objectType, Boolean checkAdditionalContent) +689 Newtonsoft.Json.JsonSerializer.DeserializeInternal(JsonReader reader, Type objectType) +469 Newtonsoft.Json.JsonConvert.DeserializeObject(String value, Type type, JsonSerializerSettings settings) +145 Newtonsoft.Json.JsonConvert.DeserializeObject(String value, JsonSerializerSettings settings) +53 Infragistics.Web.Mvc.GridModel.DataBindInternal() +1203 Infragistics.Web.Mvc.GridModel.DataBind() +45 Infragistics.Web.Mvc.InfragisticsSuite`1.SetupGrid(IGridModel gridViewModel) +53 ASP._Page_Views_Item_List_cshtml.Execute() in d:\TFS\Cyberbahn\Development\Net\Mdo\Intranet\Views\Item\List.cshtml:151 System.Web.WebPages.WebPageBase.ExecutePageHierarchy() +252 System.Web.Mvc.WebViewPage.ExecutePageHierarchy() +147 System.Web.WebPages.StartPage.ExecutePageHierarchy() +86 System.Web.WebPages.WebPageBase.ExecutePageHierarchy(WebPageContext pageContext, TextWriter writer, WebPageRenderingBase startPage) +104 System.Web.Mvc.ViewResultBase.ExecuteResult(ControllerContext context) +375 System.Web.Mvc.<>c__DisplayClass1a.<InvokeActionResultWithFilters>b__17() +31 System.Web.Mvc.ControllerActionInvoker.InvokeActionResultFilter(IResultFilter filter, ResultExecutingContext preContext, Func`1 continuation) +436 System.Web.Mvc.ControllerActionInvoker.InvokeActionResultFilter(IResultFilter filter, ResultExecutingContext preContext, Func`1 continuation) +436 System.Web.Mvc.ControllerActionInvoker.InvokeActionResultFilter(IResultFilter filter, ResultExecutingContext preContext, Func`1 continuation) +436 System.Web.Mvc.ControllerActionInvoker.InvokeActionResultFilter(IResultFilter filter, ResultExecutingContext preContext, Func`1 continuation) +436 System.Web.Mvc.Async.<>c__DisplayClass25.<BeginInvokeAction>b__22(IAsyncResult asyncResult) +187 System.Web.Mvc.Async.AsyncControllerActionInvoker.EndInvokeAction(IAsyncResult asyncResult) +38 System.Web.Mvc.<>c__DisplayClass1d.<BeginExecuteCore>b__18(IAsyncResult asyncResult) +27 System.Web.Mvc.Async.<>c__DisplayClass4.<MakeVoidDelegate>b__3(IAsyncResult ar) +25 System.Web.Mvc.Controller.EndExecuteCore(IAsyncResult asyncResult) +52 System.Web.Mvc.Async.<>c__DisplayClass4.<MakeVoidDelegate>b__3(IAsyncResult ar) +25 System.Web.Mvc.Controller.EndExecute(IAsyncResult asyncResult) +38 System.Web.Mvc.<>c__DisplayClass8.<BeginProcessRequest>b__3(IAsyncResult asyncResult) +41 System.Web.Mvc.Async.<>c__DisplayClass4.<MakeVoidDelegate>b__3(IAsyncResult ar) +25 System.Web.Mvc.MvcHandler.EndProcessRequest(IAsyncResult asyncResult) +38 System.Web.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +602 System.Web.HttpApplication.ExecuteStepImpl(IExecutionStep step) +195 System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously
Hello Yuri,
Thank you for the provided grid configuration and explanation. I would appreciate if you please provide the whole Controller and View files as well, as they may turn out to be very important when investigating the possible cause of this behavior.
Those files would help me create a more isolated MVC sample on my side, where the issue reproduces, so I could debug and find what is causing this error message and the problems with deserializing the JSON.
I look forward to your reply.
It is error scenario for one grid. I have MVC4 controller and view:
- The action is ActionResult List(CustomerSearchModel search). The CustomerSearchModel extends GridModel
- The controller creates DataSource for grid model. It is DataSet with DataTable
search.DataSource = <data set> search.DataMember = <table name>;
- The view create form with @using (Html.BeginForm("List", "Customer", FormMethod.Post)). The form has grid and other buttons and fields.
- The form has Refresh button that refresh full form and grid (posting on the current action). $('#btnRefresh').click(function (e) { $('#spinner').show(); $(this).closest('form')[0].submit(); });
- The model has some features. See below.
- The posting has internal JSON error in grid model when I create grid with new data after click on the Refresh button. Can I disable internal JSON deserialization for the grid?Infragistics.Web.Mvc.GridModel.DataBindInternal()
This error usually gets thrown when you try to deserialize something that is not a valid JSON, or not JSON at all – a similar issue is discussed in this StackOverflow thread.
I would suggest that you try the two online tools that the answer there suggests: one is for validating the JSON and the other one - to generate C# from it.
Some additional information with regard to your scenario would be much appreciated:
I look forward to hearing from you.
