Hi,Suppose the hierarchical grid structure is like-A1 --> A1B1 ---> C11
---> C12
---> A1B2 ----> C21
---> C22A2 --> A2B1 --.> C31
---> C32 ---> A2B2 --> C41
----> C42Where, A1 represnt the first row of topmost grid, A1B1 and A1B2 are its child and so onSuppose, I expand the A1 row, then A2 should be collapsed and vide versa, now inside A1, if A1B1 is expanded, A2 will remain collapsed but, and A1B2 will also be remain collapsed and similarly if A1B2 is expanded, then A1B1 is collapsed.. Going one more level down.. Suppose child 1 of A1B1 is expanded, then all other children of A1B1 should be collapsed, and so on.Hope I make myself clear.How can I achieve this functionality on level wise, i.e If a row of ith level is expanded then all other rows at same level will be collapsed and also all other rows at (i-1)th level should remain collapsed except the parent at (i-1)
Yes,var data = $(ui.parentrow.context).find("table[data-childgrid=true]").data().igGrid.dataSource.data();http://stackoverflow.com/questions/28834146/getting-entries-of-child-grids-of-currently-expanded-row-in-ighierarchicalgrid/
Hi Amritesh,
Did you manage to resolve the issue? If you need further assistance please let me know.
Tsanna
Please try accessing the column layouts that belong to the expanded row using the following code inside 'rowExpanded' event:
args.owner.options.columnLayouts[0].columns
If you want to access the key of certain column, you may do it using for instance: args.owner.options.columnLayouts[0].columns[0].key
Is this what you're looking for?
This will not give all the parents up the hierarchy. 2 options I need-
1) Either all the parents up the level
2) Or, all the child of the row being expanded
You can access the expanded parent row on rowExpanded event through the event arguments, for instance:
rowExpanded : function(e, args) {
//jQuery wrapper of the parent row object
args.parentrow
