We have this version live in Production today. We found out there is a bug with this version of the igCombo control. We discovered the cause too late to update to the next service release that contains the actual fix.
Are there any known work around to get this functionality working again?
Hello Karthik,
Thank you for the update. There isn’t a specific workaround for that issue. If you are unable to upgrade to the latest service release I would recommend downloading the source code/JavaScript and manually make the changes to your files that relate to this change that fixed this. If you provide me with the TFS number I can look up some of that information for you in a private case.
Crap, I didn't explain why it doesn't work :)
The igselectionchanged event does not fire when selecting many records. It will always fire for the first record, but not any subsequent.
We can't upgrade because we would need to QA the entire application even if it has no changes in the event that the service release causes any issues. We haven't budgeted for that extra time.
A workaround would depend on what the issue you are having is. Without knowing the issue one thing that could be done is you could download the latest source code that has the change and then make the change manually in your code. Is there a reason you can’t just update to the latest service release?
