40
Show second series in Ignite UI ASP.NET Helper DataChart Example
i am currently trying to implement the ASP.NET MVC Helper DataChart example (see this link: www.igniteui.com/.../aspnet-mvc-helper) and its working really well execpt i couldn't figure out so far how to add a second series of data.
1. The Controller code is the same as in the example.
2. My view looks like this:
@using Infragistics.Web.Mvc
@model FatKarli.WebUI.Controllers.ChartController.StockMarketDataCollection
<!DOCTYPE html>
<html>
<head>
    <title></title>
    <!-- Ignite UI Required Combined CSS Files -->
    <link href="">cdn-na.infragistics.com/.../infragistics.theme.css" rel="stylesheet" />
    <link href="">cdn-na.infragistics.com/.../infragistics.css" rel="stylesheet" />
    <!--CSS file specific for chart styling -->
    <link href="">cdn-na.infragistics.com/.../infragistics.ui.chart.css" rel="stylesheet" />
    <script src="">modernizr.com/.../script>
    <script src="">code.jquery.com/.../script>
    <!-- Ignite UI Required Combined JavaScript Files -->
    <script src="">cdn-na.infragistics.com/.../script>
</head>
<body>
    <style type="text/css">
        #chart {
            position: relative;
            float: left;
            margin-right: 2%;
            margin-bottom: 2%;
            min-width: 210px;
        #legend {
            position: relative;
            float: left;
    </style>
    <div style="height: 400px">
        @(Html.Infragistics().DataChart(Model.AsQueryable())
              .ID("chart")
              .Width("800px")
              .Height("400px")
              .VerticalZoomable(true)
              .HorizontalZoomable(true)
              .Title("Zeitdarstellung")
              .Legend(legend => legend.ID("legend"))
              .OverviewPlusDetailPaneVisibility(Visibility.Visible)
              .Axes(axes =>
                  axes.CategoryX("xAxis")
                      .Label(item => item.FormattedDate);
                  axes.NumericY("yAxis")
                      .Title("X [mm/s]");
                      .Series(series => series
                          .Line("series1")
                          .ValueMemberPath(item => item.Open)
                          .Title("X")
                          .XAxis("xAxis").YAxis("yAxis")
                          .ShowTooltip(true)
                          .Line("series2")
                          .ValueMemberPath(item => item.UpperLimit)
                          .Title("Upper Limit")
                          .ShowTooltip(true)
              .DataBind()
              .Render())
    </div>
</body>
</html>
3. My Model is the same as in the example except there is another field "UpperLimit" which is always 100.
When i run the application i can only see the second series (a constant line at y = 100) is shown. When i uncomment the second series, the random value series from the example is visible. But i would like them to be shown at the same time.
Can anyone tell me how to handle this?
