I have reduced my sample as far as I can.. I get a jacascript error in the console when I run it, and the grid appears with column headings but no data:
Exception was thrown at line 1864, column 2 in http://localhost:56929/Scripts/jquery-1.10.2.js
0x800a139e - JavaScript runtime error: Syntax error, unrecognized expression: unsupported pseudo: jqmData
ViewBag.Title = "CSM Tax Report";
@using Infragistics.Web.Mvc
@using TrackerMvc.Models.ClientTrackerDataModel.Reports
@model IQueryable<FormsByClient>
<div>
<link href="@Url.Content("~/Content/themes/infragistics/infragistics.theme.css")" rel="stylesheet" />
<link href="@Url.Content("~/Content/structure/infragistics.css")" rel="stylesheet" />
@section scripts {
<script src="@Url.Content("~/igniteui/js/infragistics.core.js")">script>
<script src="@Url.Content("~/igniteui/js/infragistics.lob.js")">script>
<script src="~/igniteui/js/infragistics.loader.js" type="text/javascript">script>
$.ig.loader({
scriptPath: '@Url.Content("~/igniteui/js/")',
cssPath: '@Url.Content("~/igniteui/css/")',
resources: "igGrid.Sorting"
script>
@(Html.Infragistics()
.Grid<FormsByClient>(Model)
.ID("Grid")
.Height("500px")
.Width("100%")
.AutoGenerateColumns(false)
.AutoGenerateLayouts(true)
.RenderCheckboxes(true)
.ResponseDataKey(null)
.Columns(column =>
column.For(x => x.FileCompID).HeaderText("File Comp ID").Width("35%");
column.For(x => x.FiledMethodId).HeaderText("Filed Method ID").Width("65%");
.DataSourceUrl(Url.Content("~/ct/FormsByClientJson/1/2015/C"))
.Render()
div>
private GridModel GridLoadOnDemandModel()
// Define the Categories layout
GridModel grid = new GridModel();
grid.AutoGenerateLayouts = true;
grid.AutoGenerateColumns = false;
grid.Width = "100%";
grid.PrimaryKey = "FileCompID";
grid.Columns.Add(new GridColumn() { HeaderText = "FileCompID", Key = "FileCompID", DataType = "number", Width = "15%" });
grid.Columns.Add(new GridColumn() { HeaderText = "FiledMethodId", Key = "FiledMethodId", DataType = "number", Width = "85%" });
return grid;
[Route("FormsByClientJson/{id:int}/{fileyear:int}/{filetype:alpha}")]
public JsonResult FormsByClientJson(int id, int fileyear, string filetype)
GridModel model = GridLoadOnDemandModel();
model.DataSource= new List<FormsByClient>()
new FormsByClient() { FileCompID = 1, FiledMethodId = 10 },
new FormsByClient() { FileCompID = 2, FiledMethodId = 20 }
}.AsQueryable();
return model.GetData();
namespace TrackerMvc.Models.ClientTrackerDataModel.Reports
public class FormsByClient
public int FileCompID { get; set; }
public int FiledMethodId { get; set; }
JSON Returned by Datasourceurl =
{"Records":[{"FileCompID":1,"FiledMethodId":10},{"FileCompID":2,"FiledMethodId":20}],"TotalRecordsCount":0,"Metadata":{"timezoneOffset":-21600000}}
I'm glad to see that you found the solution and post it to our community. If you have any other questions regarding this matter, please let us know.
Nevermind.. the offending line was this:
Started working after I removed it. I copied it from an example and (mistakenly) thought it meant it would default to default value instead of null.
Deyan,
Thank you for your suggestions.If I comment out the loader I get the same behavior.If I comment out the two script lines you mention I get this error:Unhandled exception at line 77, column 47 in http://localhost:56929/Ct/CsmTaxReport0x800a01b6 - JavaScript runtime error: Object doesn't support property or method 'igGrid'
Does it matter what the controller looks like if I go to the url specified in the .DataSourceUrl and it returns the Json I included?
I included it above but here it is again:
Hello Greg Pringle,
Thank you for posting into our community!
Using loader
and the scripts
at the same time is not recommended since you are referring the same scripts twice
I didn't manage to find the action of your controller. Can you send the reduced sample or inform us how does your action in the controller look like.
