Hi, i'm using the igHierarchical grid trying to setup a master child view. the parent table is getting data from a rest call. I want to make a seperate rest call for the child details for that given parent row (passing the primary key).
i've found documentation on line for mvc and some javacsript solutions but nothing is working for me. i only want to load the child rows ondemand..i've looked up that feature as well. can someone please help? do i need to do put additional code in the grid's click handler()?
if there was some kind of way, when defining the grid, i could say "childDataSource: JSON.parse("/get/my/data[id='123']"). or something to that extent.
i appreciate the help. yes i am a windows guy as you can probably tell.
Al
Hello Al,
As I suggested in this forum thread you can use "igchildgridcreating" event, but instead of a JSON you can assign as a data source an Url like this:
$(document).on("igchildgridcreating", function (evt, ui) {
ui.options.dataSource = "/get/my/data[id='123']";
Hope this helps, Martin Pavlov Infragistics, Inc.
