After upgrading from 2015.1 I get this error now:
An exception of type 'System.TypeAccessException' occurred in App_Web_jzwdbamf.dll but was not handled in user code
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code. Exception Details: System.TypeAccessException: Attempt by security transparent method 'Infragistics.Web.Mvc.HtmlHelperExtensions.Infragistics(System.Web.Mvc.HtmlHelper`1<!!0>)' to access security critical type 'System.Web.Mvc.HtmlHelper`1<TModel>' failed.Assembly 'Infragistics.Web.Mvc, Version=3.15.2.1027, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb' is marked with the AllowPartiallyTrustedCallersAttribute, and uses the level 2 security transparency model. Level 2 transparency causes all methods in AllowPartiallyTrustedCallers assemblies to become security transparent by default, which may be the cause of this exception.Source Error:
Line 29: @* Line 30: *@ Line 31: @(Html.Infragistics() Line 32: Line 33: .Grid<FormsByClient>(Model)
Source File: c:\source\TrackerMvc\TrackerMvc\Views\Ct\CsmTaxReport.cshtml Line: 31 Stack Trace:
[TypeAccessException: Attempt by security transparent method 'Infragistics.Web.Mvc.HtmlHelperExtensions.Infragistics(System.Web.Mvc.HtmlHelper`1<!!0>)' to access security critical type 'System.Web.Mvc.HtmlHelper`1<TModel>' failed. Assembly 'Infragistics.Web.Mvc, Version=3.15.2.1027, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb' is marked with the AllowPartiallyTrustedCallersAttribute, and uses the level 2 security transparency model. Level 2 transparency causes all methods in AllowPartiallyTrustedCallers assemblies to become security transparent by default, which may be the cause of this exception.] Infragistics.Web.Mvc.HtmlHelperExtensions.Infragistics(HtmlHelper`1 helper) +0 ASP._Page_Views_Ct_CsmTaxReport_cshtml.<Execute>b__2() in c:\source\TrackerMvc\TrackerMvc\Views\Ct\CsmTaxReport.cshtml:31 System.Web.WebPages.<>c__DisplayClass7.<RenderSection>b__5(TextWriter tw) +316 System.Web.WebPages.HelperResult.WriteTo(TextWriter writer) +10 System.Web.WebPages.WebPageBase.Write(HelperResult result) +80 ASP._Page_Views_Shared__Layout_cshtml.Execute() in c:\source\TrackerMvc\TrackerMvc\Views\Shared\_Layout.cshtml:47 System.Web.WebPages.WebPageBase.ExecutePageHierarchy() +197 System.Web.Mvc.WebViewPage.ExecutePageHierarchy() +105 System.Web.WebPages.WebPageBase.ExecutePageHierarchy(WebPageContext pageContext, TextWriter writer, WebPageRenderingBase startPage) +90 System.Web.WebPages.<>c__DisplayClass3.<RenderPageCore>b__2(TextWriter writer) +232 System.Web.WebPages.HelperResult.WriteTo(TextWriter writer) +10 System.Web.WebPages.WebPageBase.Write(HelperResult result) +80 System.Web.WebPages.WebPageBase.RenderSurrounding(String partialViewName, Action`1 body) +63 System.Web.WebPages.WebPageBase.PopContext() +237 System.Web.WebPages.WebPageBase.ExecutePageHierarchy(WebPageContext pageContext, TextWriter writer, WebPageRenderingBase startPage) +98 System.Web.Mvc.RazorView.RenderView(ViewContext viewContext, TextWriter writer, Object instance) +235 System.Web.Mvc.BuildManagerCompiledView.Render(ViewContext viewContext, TextWriter writer) +107 System.Web.Mvc.ViewResultBase.ExecuteResult(ControllerContext context) +291 System.Web.Mvc.ControllerActionInvoker.InvokeActionResult(ControllerContext controllerContext, ActionResult actionResult) +13 System.Web.Mvc.ControllerActionInvoker.InvokeActionResultFilterRecursive(IList`1 filters, Int32 filterIndex, ResultExecutingContext preContext, ControllerContext controllerContext, ActionResult actionResult) +56 System.Web.Mvc.ControllerActionInvoker.InvokeActionResultFilterRecursive(IList`1 filters, Int32 filterIndex, ResultExecutingContext preContext, ControllerContext controllerContext, ActionResult actionResult) +420 System.Web.Mvc.ControllerActionInvoker.InvokeActionResultWithFilters(ControllerContext controllerContext, IList`1 filters, ActionResult actionResult) +52 System.Web.Mvc.Async.<>c__DisplayClass2b.<BeginInvokeAction>b__1c() +173 System.Web.Mvc.Async.<>c__DisplayClass21.<BeginInvokeAction>b__1e(IAsyncResult asyncResult) +100 System.Web.Mvc.Async.WrappedAsyncResult`1.CallEndDelegate(IAsyncResult asyncResult) +10 System.Web.Mvc.Async.WrappedAsyncResultBase`1.End() +49 System.Web.Mvc.Async.AsyncControllerActionInvoker.EndInvokeAction(IAsyncResult asyncResult) +27 System.Web.Mvc.Controller.<BeginExecuteCore>b__1d(IAsyncResult asyncResult, ExecuteCoreState innerState) +13 System.Web.Mvc.Async.WrappedAsyncVoid`1.CallEndDelegate(IAsyncResult asyncResult) +29 System.Web.Mvc.Async.WrappedAsyncResultBase`1.End() +49 System.Web.Mvc.Controller.EndExecuteCore(IAsyncResult asyncResult) +36 System.Web.Mvc.Controller.<BeginExecute>b__15(IAsyncResult asyncResult, Controller controller) +12 System.Web.Mvc.Async.WrappedAsyncVoid`1.CallEndDelegate(IAsyncResult asyncResult) +22 System.Web.Mvc.Async.WrappedAsyncResultBase`1.End() +49 System.Web.Mvc.Controller.EndExecute(IAsyncResult asyncResult) +26 System.Web.Mvc.Controller.System.Web.Mvc.Async.IAsyncController.EndExecute(IAsyncResult asyncResult) +10 System.Web.Mvc.MvcHandler.<BeginProcessRequest>b__5(IAsyncResult asyncResult, ProcessRequestState innerState) +21 System.Web.Mvc.Async.WrappedAsyncVoid`1.CallEndDelegate(IAsyncResult asyncResult) +29 System.Web.Mvc.Async.WrappedAsyncResultBase`1.End() +49 System.Web.Mvc.MvcHandler.EndProcessRequest(IAsyncResult asyncResult) +28 System.Web.Mvc.MvcHandler.System.Web.IHttpAsyncHandler.EndProcessRequest(IAsyncResult result) +9 System.Web.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +9711525 System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +155
Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.6.81.0
The Upgrade wizard seems to have made the upgraded reference point to the MVC3 version of the infragistics controls. Change the reference to the MVC5 version and the error went away.
Error happens with Upgrade wizard for 2016.1 also. Thanks for your suggestion, replacing the Infragistics.Web.Mvc.dll with the correct version fixes this problem.
